Hood Hinge Spring Installation.....
Discussion in 'Tips 'n' Tricks Topic' started by Twisted_Metal, Mar 21, 2009.
  1. TeamWarpath
    TeamWarpath Veteran Member
    590
    May 20, 2007
    Lexington, KY
    i used a crapload of washers and screws and hammered the little suckers all around the spring. Of course, when you get the spring on and lower the hood, you have a BIG mess to clean up...LOL
  2. barno68
    barno68 Member Gold Member
    75
    Mar 29, 2006
    Dublin, CA
    Screwdriver? I could barely get mine to budge, so used the winch on my car trailer... made a quick job of it.
    Brent
  3. KansasTwister
    KansasTwister Veteran Member Lifetime Gold Member
    1,389
    Oct 7, 2006
    Lawrence, ks
    Me and my old man fabricated a tool just for removing hood springs, ill take a picture tommorow and post it up, really simple design and works in alot of different applications, and completely safe to use.
  4. theflash
    11,040
    34
    Feb 27, 2004
    Podunk, CT
    Clothes pins
  5. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    gotta have the guns for that job
  6. barno68
    75
    Mar 29, 2006
    Dublin, CA
    LOL
  7. DaveD
    DaveD Member
    43
    Nov 29, 2008
    Ashebro, North Carolina
    Here is the tool I made.
  8. Twisted_Metal
    27,049
    994
    ^ That will work! :D
    Can you get the hinge inside the frame to reassemble it or did you have to stuff something between the coils to keep it stretched?
  9. DaveD
    DaveD Member
    43
    Nov 29, 2008
    The frame fits on the outside of the hinge and the hooks simply pull the spring off of the hinge by tightening up on the nuts, I left them in the frame to bead blast and paint then put them back on the hinge by lining the spring up and backing off the nuts.
    Worked great and cost about $5.
  10. krabben1
    8,160
    45
    May 16, 2007
    ( . Y . )Delco
    Whats the funnel for?
