Hood hinge spring replacement
Discussion in 'Tips 'n' Tricks Topic' started by dailycruiser81, Apr 24, 2017.
  1. dailycruiser81
    dailycruiser81 Veteran Member
    207
    10
    May 19, 2013
    ft lauderdale
    Does anyone have any tricks or tips on replacing hood springs?
  2. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    Wedge the (wood) halves of some disassembled wooden clothespins in between the coils while the spring is extended (hood open but lowered as much as possible). Then raise the hood and the spring should be easy to unhook. Any thin scraps of wood (like pieces of paint sticks) will work, too.
    As for installing the new ones, hook one end to something sturdy (beam, tree, truck hitch, etc) and use a come-along (or maybe a ratchet strap) to stretch the spring. Place the wooden spacers in between the coils until the spring is long enough to easily hook onto the hinge. Don't catch your fingers between the coils!
  3. 351maverick
    351maverick Veteran Member
    3,611
    389
    Aug 11, 2010
    erie, PA
    quick grip type bar clamp...like the woodworking kind
    ratchets them on & off
  4. 12BoltPosi
    12BoltPosi New Member
    12
    Dec 16, 2011
    Vallejo, Ca
    image.jpeg If you have an engine hoist and chains then it'll be a breeze. Hook the spring ends to chains and fasten the chains to the hoist arm and the base of the hoist and slowly raise the hoist just enough to remove the hood hinge. It's safe and easy
    71smalbloc, Jrod79Z and Zstar like this.
  5. Zspoiler
    Zspoiler Veteran Member
    3,208
    250
    May 6, 2012
    Federal Way, Washington
    I just use the largest Craftsman flat tip screw driver I have and just pop them on and off..With or without the hood on. Its easy. There is no use in over engineering stuff when doing anything.I prescribe to th K.I.S.S theory.Kiss it simple stupid.
  6. Gary S
    22,409
    751
    Somebody posted here a while back that it can be done easily using a double ended open end wrench. He simply found the right length wrench that fit into the ends of the spring when it was stretched. Then, simply release it by moving the hood. The wrench holds the spring so it can't shorten.
  7. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,119
    61
    Feb 23, 2009
    San Diego, CA
    Here's what I just did and it worked like a charm. Tried inserting several screwdrivers into the spring and using washers between each coil in order to keep it spread open, but nothing worked. Found an old metal coat hanger and setup the spring on the jack as you can see here. As soon as the hinge came loose, I removed it and lowered the jack. Felt pretty safe to me.
    NeoNeuro likes this.
  8. Jeep43
    Jeep43 Veteran Member
    1,282
    45
    Mar 30, 1999
    Connecticut
    I stretched mine between two deck posts using light duty ratchet straps, inserted the hinge into the spring ends and relaxed the straps and viola!
  9. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    wish I had seen this before I put my hood back on.
