Hood Hinges
Discussion in 'Body Restoration' started by mrfleet12, May 12, 2019.
  1. mrfleet12
    mrfleet12 Veteran Member
    214
    28
    Aug 8, 2014
    West of Chicago IL
    Hello
    Need to replace my hood hinges, right one is getting weak at the joints and is bending in... Looking at some on eBay, The Parts Place (10 mins from my house) and other online stores... Is there any difference or a better way to ask that, are there some that are a better quality?
    My hood is an aftermarket steel cowl hood..
    Saw these on eBay, springs and hinges for $147 seems pretty cheap..
    Part Place is $160 for the hinges, no springs, my springs still seem to be fine, just the hinges are fading..
    Any input is appreciated..
    Thanks
    Fleet
  2. 8pack
    2,535
    117
    Aug 29, 2007
    Pittsburgh, PA
  3. mrfleet12
    214
    28
    Aug 8, 2014
    West of Chicago IL
    Thanks, I'll check them out.
  4. Zspoiler
    Zspoiler Veteran Member
    2,992
    206
    May 6, 2012
    Federal Way, Washington
    I used a set from OER for my 1979 Z-28 with no issues
    mrfleet12 likes this.
  5. hubedobeedo
    hubedobeedo 3rd times a charm
    207
    37
    Jul 18, 2013
    Huntertown,IN
    i took the original hinges and used a press and repressed the pins because of slop they are like new now. i bought aftermarket springs they sucked ,somebody on ebay was swapping over to glass hood and did not need his original springs i jumped on them glad i did. nothing beats original.sometimes you have to manipulate what you have to make it work instead of "buying new"
  6. mrfleet12
    214
    28
    Aug 8, 2014
    West of Chicago IL
    hubedobeedo
    Were your hinges bowing in at the front, that's the issue with mine..
  7. hubedobeedo
    207
    37
    Jul 18, 2013
    Huntertown,IN
    they were "loose" sloppy they weren't so much bowed in,do you mean the hinge was bent?the 2 upright bars should be fairly straight looking from the front.the pins that i am pointing at are the ones i repressed,i modified a piece of round metal stock to somewhat replicate the notches i had a helper hold the hinge while i used the press i did numerous presses to make sure as to not get them to tight the springs need to be off the hinge when doing this they seem to work a lot better. i do think that they are not a very well designed hinge,i looked at doing a different setup but these were on the car (all about recycling)
  8. hubedobeedo
    207
    37
    Jul 18, 2013
    Huntertown,IN
    one more pin pic
  9. hubedobeedo
    207
    37
    Jul 18, 2013
    Huntertown,IN
    man its early i just got up LOL this is the other pic
  10. mrfleet12
    214
    28
    Aug 8, 2014
    West of Chicago IL
    Sounds pretty straightforward, these are mine currently. Hood still closes ok.
    hubedobeedo and Dichard like this.
