Hood latch assembly
Discussion in 'Body Restoration' started by gpm6367, Aug 12, 2019.
  1. 70lt1z28
    3,120
    581
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Good idea. When you make one part too good, it really stands out. Better to strip it down and just put a good rust preventative like Fluid Film, Sharkhide or Boeshield on it.
    hubedobeedo and gpm6367 like this.
  2. gpm6367
    793
    44
    Feb 12, 2005
    New Joisey
    Lacquer thinner didn’t work. Trying aircraft paint stripper. Don’t want to use abrasives or it will take any original finish with it...
  3. gpm6367
    793
    44
    Feb 12, 2005
    New Joisey
    8246D571-5AE3-43AE-9E4E-4A1C038E432B.jpeg 23D82AE6-D36A-401B-936A-BAFB326C85DA.jpeg 8B921E14-C455-47AE-957E-8219633A81B4.jpeg I have to say it would have been a lot easier to throw this in the blasting cabinet and take it down to bare metal in no time. But after many applications of paint stripper and avoiding the use of any type of abrasive or sanding material, there is plenty of original zinc phosphate on there complete with patina.
    For my purposes now, when I am not completely restoring the engine bay, this is perfect. I’m going to remove the lower section as well as the male portion of the hood release and strip them as well.
    hubedobeedo and 70lt1z28 like this.
  4. 70lt1z28
    3,120
    581
    Oct 3, 1999
    Looks pretty good for sure.
  5. gpm6367
    793
    44
    Feb 12, 2005
    New Joisey
    519AFB56-5EE5-4F8D-990B-1E3D455850AF.jpeg 879BF765-B037-43B5-8267-D07734D7DE6A.jpeg C3890A79-E9F2-4BDB-9AB2-EE96459118C7.jpeg 7563E14B-0146-4195-BC2E-03090C416D54.jpeg
    Why do people spray bomb black? Seriously if your not going to refinish don’t bother...still need finishing with lacquer thinner and .00 steel wool
    hubedobeedo likes this.
  6. gpm6367
    793
    44
    Feb 12, 2005
    New Joisey
    1C4548B7-4AFD-46E4-B7ED-9BC0D3DD03EB.jpeg Wiped down engine bay. Looped Heater hoses so can run but gaping hole in firewall. Need those heater parts...
  7. gpm6367
    793
    44
    Feb 12, 2005
    New Joisey
    98212ADF-80BB-4834-9B52-831487343DB2.jpeg Clearly the vertical support is not zinc phosphate coated. That is bare metal and I need to paint it.
    What black do you guys use for engine bay supports like this? There are a lot of semi-gloss blacks out there. I use rustoleum 7777 semi gloss for Fords but think it’s a little to glossy for GMs.
  8. 70lt1z28
    3,120
    581
    Oct 3, 1999
    Depends on how deep you want to get into it.
    For spray bomb I use a Krylon semi flat 1613 from the industrial products line of Krylon paint. This is different from the Krylon paint you get at the local hardware store.
    Otherwise if you want to go full bore with a spray gun then I would recommend PPG Delfleet Essential with a activator and hardener with the DX10 flattener to 30% gloss. That’s my current favorite but there a many different chassis blacks. 30% gloss is what you are looking for
  9. gpm6367
    793
    44
    Feb 12, 2005
    New Joisey
    1BC1FC5E-D80F-4781-9688-30C35B778925.jpeg 1BD721A0-34CE-408D-93CB-4D80BDCBEA16.jpeg
    For that one bracket spray bomb will be fine. I’ll either go Krylon or the Rustoleum 7777. I read other threads on here that have used as well.
    Also the male latch assembly is not zinc phosphate either. Looks like remnants of black phosphate. I am leaving it as is for now.
  10. gpm6367
    793
    44
    Feb 12, 2005
    New Joisey
    C731F93F-2632-480B-B301-7AB5ECB9A77C.jpeg Also what type of fastener holds the top of bracket through the grille hole? My top square, pictured here, had a modified white plastic license plate nut and Phillips screw.
