hooker cross member
Discussion in 'High Tech Retrofits' started by 5spd540, Dec 21, 2013.
  1. PolarBear
    1,189
    Apr 24, 2008
    NJ
    I don't know about the monuting heights, but the Speedtech crossmember is super adjustable. It is slotted and the brackets can flip around, so many different transmissions and locations can be accounted for. I have one in my car for the T56. I had an aftermarket T56 behind my BBC and now I have an LS1 T56 behind an LSx engine and I have the engine set back 1.25" referencing the bellhousing to a stock SBC/BBC location. This crossmember has been able to do everything I have needed it to do. and plenty of room for exhaust Here it is at $359, it was a lot less when I bought it from ATS though
    Couple pictures of what I mean
    You can flip the brackets left/right to get more adjustability out of the setup too.
    Installed
  2. 5spd540
    12,399
    17
    Sep 19, 2009
    Guyton, GA
    Do you have any pics
  3. PolarBear
    1,189
    Apr 24, 2008
    NJ
    Updated with pictures
  4. 5spd540
    12,399
    17
    Sep 19, 2009
    Guyton, GA
    How does it mount to the frame rails? I cant really tell
  5. PolarBear
    1,189
    Apr 24, 2008
    NJ
    The slotted bracket mounts using the stock crossmember holes, then the billet end piece slides in the bracket, and the holes for the crossmember are slotted too, so you can adjust in/out. If you look at the Speedtech page it should be a little more evident what I am talking about.
    That picture is actually showing it assembled wrong, I think, unless I put it in the car wrong. I don't remember getting instructions with it
  6. 5spd540
    12,399
    17
    Sep 19, 2009
    Guyton, GA
    Never mind I missed the link the 1st time.
  7. PolarBear
    1,189
    Apr 24, 2008
    NJ
    I edited my post about 5 times too, and you were looking at the same time
  8. 5spd540
    12,399
    17
    Sep 19, 2009
    Guyton, GA
    That looks like a very nice piece you have
  9. toddoky
    toddoky Veteran Member
    227
    Mar 5, 2013
    Bowling Green, KY
    This photo of the 12614HKR Hooker 4L60-4L75 crossmember might show it a little more clearly...if someone is installing one of the Hooker crossmembers on a subframe that is out of the car for restoration or repair then the holes in the tabs resting on the top of the subframe can be drilled straight down through the subframe for installation.
    If the subframe is not going to be removed from the car for any reason during the project, then the crossmembers can be side mounted to the subframe rails using the included angle brackets.
  10. 5spd540
    12,399
    17
    Sep 19, 2009
    Guyton, GA
    Yea my frame is in my car permeate since I welded the frame connectors in last year
