hooker long tube for 1973 camaro ls swap
Discussion in 'High Tech Retrofits' started by cisco 1, Oct 6, 2019.
  1. cisco 1
    cisco 1 Member
    30
    9
    Apr 14, 2019
    quebec,canada
    i have 73 camaro and i have a deal on 75-81 hooker long tube headers . most off company liste 1970-81 the same but what hare the frame difference so hookers have different fitment for 70-74 and 75-81 headers .
    the 73 motor mount hare the big one the same as 81 or most 73 up gm .
    can i make those 75-81 stanless long tube header fit my 73 ?
  2. QUAKE_WARS
    QUAKE_WARS Veteran Member
    1,976
    137
    Dec 19, 2008
    I use all holley ls swap stuff and never had an issue. It would be best for you to call holley and ask whats the difference
    and see if you can modifiy from there.
  3. badazz81z28
    16,409
    407
    Las Vegas, NV
    I can’t imagine what would make them different.
  4. 75Maro
    75Maro Veteran Member
    427
    17
    Mar 31, 2008
    Dallas,Tx
    I actually bought the 70-73 set off CL for my 75 and they fit no problems
  5. cisco 1
    cisco 1 Member
    30
    9
    Apr 14, 2019
    quebec,canada
  6. markster
    markster New Member
    Oct 21, 2018
    Allentown, PA
    cisco 1 likes this.
  7. Bobby G
    Bobby G Veteran Member
    121
    Jan 2, 2010
    Rochester, N.Y.
    How is the clearance from the ground on them, do you have some pics of them?
  8. Brian
    Brian Veteran Member
    355
    Aug 12, 1999
    OHIO
    I thought there was a difference in how low the collector hung below the car. I was pretty sure the earlier version hung a little lower do to a variation in the floor board or something. If I remember right, a member on here complained his seemed to low and he then tried the latter version on his pre 74 model, said there was no fitment issue and didn't hang as low.
