Hooker T56 Shifter Hump
Discussion in 'Transmission & Driveline Topics' started by Bill70, Aug 16, 2016.
  1. Bill70
    Bill70 Veteran Member
    234
    14
    Jan 8, 2012
    Phoenix, AZ
    I recently bought the Hooker T56 shifter hump to fit over my T56 Magnum. I had made 2 previous floor patches myself but was not really happy with the way they looked. It's a heavy gauge piece that fit the floor pretty well. I had to bend the flanges a bit to fit flat to the floor. The top has a flange around the edge which is designed to allow you to get to all of the shifter bolts, if needed. i covered the opening with a piece of sheetmetal and then mounted a shifter boot over it. Works good, is functional and looks a lot better than anything I could have made.
  2. BonzoHansen
    19,397
    771
    Jun 1, 2005
    Scott from Hamilton, NJ
    Nice. Thank god the one i made is hidden by carpet and console lol
  3. badazz81z28
    16,728
    465
    Las Vegas, NV
    Huh...I didn't know that existed. Does it fit under the carpet?
  4. Bill70
    234
    14
    Jan 8, 2012
    Phoenix, AZ
  5. badazz81z28
    16,728
    465
    Las Vegas, NV
    Looks like it sits pretty high. I like it, but don't want to blow $60 if it doesn't fit under an OEM cut carpet. I may just have to try it.
  6. thesalboy
    thesalboy Veteran Member
    345
    111
    Mar 25, 2017
    Los Angeles, CA
    Bill70, what shifter position are you using? 1 (forward position), 2 (front of the back position), or 3 (rear of the back position)? Are you further offsetting shifter position fore or aft? How far back from the trans tunnel panel seam is the leading edge of the hump? How much clearance do you have between shifter and rear of hump opening?
    I can only get 1 out of 3 pics to come through (using Photobucket embedded image fix). I can see only the first one. Do you still have the other 2? Or any others showing outer flange locations?
    Trying to install the hump in my 1974 Camaro while it's still a bare shell. There is no documentation from Holley. I'm using the FBody LS1 T56, and the shifter is 2.9" further back from Magnum position 3. Kind of looks like any further back and the hump will hit the seats.
    Thanks much for any input you can provide!
  7. badazz81z28
    16,728
    465
    Las Vegas, NV
    Anyone know if it fits under the carpet? I don’t nor want to run a console
  8. Goat
    1,905
    44
    Jun 7, 2001
    moncure, NC
    I bought one I decided not to use if you are interested...
  9. thesalboy
    345
    111
    Mar 25, 2017
    Los Angeles, CA
    Same here! I thought I could make it work with Fbody T-56 but it's really Magnum-only. Holley says it fits under the stock console - no idea about carpet, but it's pretty large. I would assume not.
  10. Goat
    1,905
    44
    Jun 7, 2001
    moncure, NC
    My reason to not use it has nothing to do with fitment or carpet, I just decided to make my own...
