Horn shocking me!
Discussion in 'Troubleshooting & Diagnosis' started by bondora68, Jan 16, 2020.
  1. bondora68
    bondora68 New Member
    8
    Dec 14, 2014
    Mobile, AL
    Hi friends,
    My 75 Camaro Type LT is all original. The horn was not working so I replaced the horn unit (it tested bad) and replaced the horn button kit at the steering wheel. Now the horn blows continuously and shocks me if I touch any metal part in the steering wheel. If I disconnect the horn (under the hood) the battery drains. The only solution I have found is to remove the metal plate under the horn button but now I have no working horn.... Anyone know whats going on?
  2. CorkyE
    10,453
    508
    Sounds like it's not assembled correctly. Plenty of info via Google, here's a diagram on NastyZ. http://nastyz28.com/tech/e-horn.jpg
    BTW, I've never been shocked by 12 volts from the battery, coil and condenser have bitten me several times.
  3. BillyDean7173
    BillyDean7173 Veteran Member
    1,698
    363
    May 21, 2014
    Hutto, TX
    Not making fun of your problem, bondora68. Just an excuse to play some vintage Ace Frehley "Shock Me".
    f-body freak and bondora68 like this.
  4. Revin
    Revin Veteran Member
    554
    91
    Aug 31, 2016
    Round Rock , TEXAS
    I was shocked with my horn.
    it sounded wimpy I expected more from it.
    BillyDean7173 likes this.
  5. bondora68
    8
    Dec 14, 2014
    Mobile, AL
    Yes, I'm talking a real shock. From 12 v! The kind that makes you jerk your hand away fast..
  6. BillyDean7173
    1,698
    363
    May 21, 2014
    Hutto, TX
    Ignition switch on your column? Do you get a shock if you put a key into the lock cylinder? I'm just throwing some stuff out there.
  7. grzewnicki
    3,448
    175
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I might check the relay.
  8. bondora68
    8
    Dec 14, 2014
    Mobile, AL
    No shock from newly replaced ignition switch....
  9. bondora68
    8
    Dec 14, 2014
    Mobile, AL
    Where is the horn relay located?
  10. flht99b
    flht99b Veteran Member
    312
    55
    Nov 28, 2014
    Knoxville, TN
    It's possible the horn kit you received has the wrong plastic part with the three raised mounts, not sure what it is called but it acts like an insulator. The three standoffs may be too short which will result in the horn continuously blowing. Another possibility is the insulator for the spring loaded pin is faulty and grounding the unit.
