Horn wire color in steering column
Discussion in 'Electrical Systems' started by johnnycamaroz, Aug 16, 2014.
  1. johnnycamaroz
    johnnycamaroz Member
    55
    Jul 22, 2014
    tucson,az
    Hey guys what color is the horn wire in the steering column in a 73 Camaro?
    Need to get the horn going.
    Thanks! johnny
  2. 73 Z
    983
    31
    Jun 9, 2007
    Los Angeles, Ca
    [​IMG][/URL][/IMG]
    black.
  3. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,065
    9
    Sep 22, 2007
    Blind Bay, B.C.
    Yup black, but there is one diagram Nasty doesn't have listed in they're electrical section and that is with the relay under the dash like in my '73 RS instead of being mounted to the engine bay firewall...
  4. johnnycamaroz
    55
    Jul 22, 2014
    tucson,az
    Thanks guys not sure where the relay is.
    I have no power to that black wire now what?
    run a hot wire to it?
  5. azkeebler
    azkeebler Veteran Member
    584
    Dec 14, 2011
    Manteca, ca.
    Black is not a power wire. It is a ground for the relay to activate the relay. You need to find the relay to determine if it has power and if the the black wire is providing the ground when you depress the the horn button.
