How do you center steering wheel on 70 z28?
Discussion in 'Troubleshooting & Diagnosis' started by Bob Bolling, Oct 18, 2019.
  1. Jeep43
    Jeep43 Veteran Member
    1,298
    48
    Mar 30, 1999
    Connecticut
    One thing I would verify is that with your steering wheel in whatever position that allows it to go straight down the road, that the pitman arm is parallel to the centerline of the car.
  2. John Wright
    14,700
    212
    Aug 9, 2002
    Rustburg, Va
    Doesn't the pitman have one spline that is larger than the rest?
  3. 70-camaro
    70-camaro Veteran Member
    2,388
    440
    Mar 25, 2010
    marietta ohio
    So does the steering wheel.
  4. Knuckle Dragger
    14,851
    1,359
    Nov 2, 2002
    Waddell AZ
    No, it should be able to go on in four different positions. Generally it will cause you to have more turns in one direction and not "feel" right when going straight, not an offset wheel as I implied above. I think Terry is more on point with the intermediate shaft issue.
  5. 70 Proof
    70 Proof Veteran Member
    546
    56
    Sep 28, 2014
    Southern Utah
    When everything else is dialed in shouldn't he ensure that the indexing marks on the steering wheel and steering shaft line up?
    w
