How hard install subframe connectors
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by muscl car, Dec 22, 2015.
  1. muscl car
    21,957
    798
    Jul 8, 2001
    High Desert of Hesperia Calif
    I've got a set of Competition Engineering bolt in subframe connectors that I want to install in my 72 Camaro . I've tried a few shops local to me and they don't want to do the install ??? :confused: . How hard is it to do this ?? , I can't myself due to injuries and not able to get under the car . May have someone help me but curios how difficult the install is
  2. Gary S
    22,782
    916
    I did a pair, but I had a hoist. With the car up on the hoist, the most difficult part was drilling the holes in the subframe to mount them.
  3. Coadster32
    1,720
    147
    Oct 2, 2013
    Milford,CT
    1) Put them up in place
    2) drill holes
    3) bolt together.
    Not much harder than that. Garage may not want the hassle of warentee issues from this type of modification.
  4. loyal guardian
    loyal guardian Veteran Member
    697
    Aug 28, 2013
    helena mt
    i havnt installed any yet but i cant imagine it to be that hard. im sure some nasty members may be close to you and able to help, if not try a less professional and more home town type shop. im sure if you check around youd find a shop thats less than brand name that would do it if you express that you understand the only warranty is the 100 yard type as in if they mess up the car in shop, its on them but once it leaves the property its on you. we have a guy out here like that. he will do anything you want him to. he takes pride in his work, but has a "if its not regular work or if you give him the part, once it leaves its not his responsibility". though he does honor his craftsmanship. there might be a shop around like that
  5. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    With the basic style, I test fitted, prepped the metal for welding, paid some guy to come and weld them in. Just make sure weight is on the wheels on a level ground.
  6. RS1979
    3,875
    806
    Jun 18, 2013
    Memphis, TN
    If you give me have your email address, I can send you the installation instructions. I don't know how to copy and post a link on my tablet.
  7. djorgensen3
    djorgensen3 Veteran Member
    508
    54
    Oct 15, 2009
    Peoria, Az
    If we were closer together, I would just do it for you...
  8. grzewnicki
    3,461
    185
    Dec 9, 2009
    Gordon from Jacksonville Fl
    It's pretty physical, drilling through the frame is not easy, even with good sharp bits, And trying to get in by the leaf springs to do the rear end of them, that was a chore. I was lucky and had a 90 degree air drill. I actually lai-d under the car and somehow got my foot on the drill to apply some pressure when drilling the front ones, still it was tough. Don't the CE ones bolt in where the bolts that hold the front spring perch to the frame? If so that end is pretty easy. Maybe a Hot Rod Shop would be willing to help you out rather than a regular garage. If you lived around here your car would be in my garage by now....
  9. Skip Fix
    Skip Fix Veteran Member
    2,193
    24
    Mar 21, 2007
    Katy,Texas
  10. David79Z28
    1,279
    41
    Oct 22, 2009
    Greenville, TX
    You have the same ones I installed on my car.
    If I can do it, anyone can!!!
