How is it done? Bracket design/fabrication
Discussion in 'The BS Topic' started by badazz81z28, Aug 15, 2019 at 8:47 PM.
  1. badazz81z28
    16,172
    377
    Las Vegas, NV
    So hear me out...I have a rear axle kit that uses corvette brakes. I want to use a smaller rotor and a Baer caliper. Everything in this kit fits, but the caliper bracket would need to be made. Where do you start to make your own bracket?
    I basically need a bracket that bolts to the black bracket to the caliper
  2. dcozzi
    dcozzi Veteran Member
    2,777
    250
    May 1, 2002
    Phoenix, AZ
    I have bought a remnant of stainless steel plate in the proper thickness, cut with a jigsaw and a LOT of cutting oil and drilled it out. Flap disc the edges smooth. Used a machinists ruler to measure the holes and a punch to start the holes to keep them exactly spaced.
    You can also clamp the piece to the plate, line up the drill bit in the hole, clamp the plate in place on the drill press, remove the piece, then drill it.
  3. 351maverick
    351maverick Veteran Member
    3,567
    373
    Aug 11, 2010
    erie, PA
    make one out of cardboard
    then one out of sheetmetal using the cardboard as a template
    then make the real thing
