How many of you have had this problem
Discussion in 'The BS Topic' started by 1980RS, Aug 23, 2019.
  1. jeff swisher
    jeff swisher Veteran Member
    1,289
    382
    Apr 26, 2018
    Yukon Oklahoma
    Brake fluid onto the threads will help break the rust loose if it is corroded into the head.
    I wonder if it is the bolt is junk or the gasket creates condensation more than manifold stuck to head with NO gasket.
    I think it is Bolt is junk as I have had aluminum head engines with iron manifolds with gaskets and 300,000 miles on them, the manifold bolts come right out never broke off.
    But that is Toyota and other foreign stuff not GM.
    1980RS likes this.
  2. Mike N
    2,736
    519
    Jan 13, 2002
    Spencerport, NY.
    Broken bolts and rotten manifolds are the soup du jour in the salt belt.
    GM, Mopar, F**d, imports..... all guilty
  3. 1980RS
    1980RS Veteran Member
    3,200
    528
    Jun 17, 2006
    MN
    LH side only has 3 bolts holding the manifold on so busting the others should be no problem. LOL
  4. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
    1980RS likes this.
  5. SRGN
    SRGN Veteran Member
    672
    234
    Feb 20, 2009
    Central NJ
    All the time. Mig welder is your friend. I build up the broken bolt enough to protrude a little bit from the head, then weld a nut to it. Blip it out with the impact and done. Sometimes a stubborn one takes a couple of tries.
    1980RS likes this.
  6. zfool
    zfool Veteran Member
    585
    16
    May 19, 2014
    Rochester, MN
    The manufacturers have proven that they can’t afford to use $2 worth of hardware on a $50K truck. So we keep buying them lol
    1980RS likes this.
  7. ZCarr
    ZCarr Veteran Member
    104
    Nov 5, 2007
    Central NJ
    I ended up buying new manifolds on eBay, it was less aggravation.
  8. 1980RS
    3,200
    528
    Jun 17, 2006
    MN
  9. 1980RS
    3,200
    528
    Jun 17, 2006
    MN
    So i got to fix those pesky bolts today. Whoever said they turn right out is on crack, all the ones that broke off flush with the manifold were a b***h to get out. The only ones I am not getting out are the very back ones on each head, those are getting those brackets that bolt to the head and put pressure on the manifolds, cost me a little more but a lot less headaches to drill out bolts.
