How much $ to expect to spend...
Discussion in 'The BS Topic' started by gramps, Mar 15, 2019.
  1. gramps
    gramps Veteran Member
    704
    138
    Jul 5, 2009
    mankato, mn
    Going to have a couple quotes done on adding a concrete pad alongside my garage - enough to park a car and open the doors and drive up to, so like 12’ wide by 36’ How much might you think this to cost?
  2. tom3
    tom3 Veteran Member
    11,441
    211
    Aug 1, 1999
    ohio
    Wild guess, 6 yards at $500 a yard, $3000. Could be more depending on preparation needed.
  3. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    630
    32
    Aug 14, 2008
    Texas
    Tom3's probably not far off. Down here in Texas, it's going for about $7.50 per square foot for 4" thick, so 12x36=432sf x $7.5 is $3,240. Cost will vary depending on grading and thickness, and of course, location. the $7.50 around here is pretty common, but not sure about in Minnesota.
  4. dave@ztech
    2,153
    315
    Mar 27, 2016
    NY
    will depend, if you want a good pad that will last for years, that will require proper site prep, dig down to a solid compactable base then 4-6 inches of stone a 15Mil vapor barrier on top of that, then WWM , then concrete , then the concrete finished , and protected for drying out to fast , if you want it to last, concrete is around $130 per CY however you need to buy it in full loads to get that price , then the cost of the site work and the form work, if you find it for around $9.00 and they do all of that prep work, edit, you will need 5.3 CY so 6 CY is correct ,
  5. Fbird
    3,245
    363
    Feb 12, 2011
    atlanta, ga
    here in mid GA goes around $150-175 /yd...then the "rule of thumb" is x2 for automotive install labor (level, add wire mesh, forms and finish ) min 4" thick
    you need about 5-6 CY
  6. 73 Z
    823
    11
    Jun 9, 2007
    Los Angeles, Ca
    Hire some day labor to do the excavation/grading, spread the dirt somewhere else in the yard if possible, lay out the vapor barrier, add about 1"+ sand to aid dry time for finish, get wire mesh or better #3 or 4 rebar assemble at 2'x2'. set up a concrete co to pour and finish
