How to Bleed Coolant
Discussion in 'Troubleshooting & Diagnosis' started by motor60, Nov 18, 2011.
  1. COPO
    18,355
    1,032
    It should increase at idle. You can try another thermostat. 180 or 185. If you have a 185 in it, while driving it shouldn't go higher than 190-195 on a real hot day. When it's cooler out and you have a 185, then the temp won't go above your 185 thermostat. If you do then you have other problems. Do you have 50/50 water/antifreeze mix? When was the last time you flushed the cooling system? Got a shroud? If you have an aftermarket water pump that's pushing more water than a stock pump then your pump is the problem.
  2. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    Could be a thermostat is hanging up when the flow of water is greater.
  3. motor60
    motor60 Member
    85
    Feb 27, 2011
    So. Cal
    Going to try a performance 160 stat tomorrow and see how it does. I dont have any leaks in my system. So, im hoping this will solve my problem. If not, then im taking out the thermostat and leaving it the way it was. I didnt have any problems with heating without a stat.
  4. maxpsi
    maxpsi Veteran Member
    610
    Jul 10, 2007
    Alabama
    Sorry to dig up an old thread, but isn't there a tool out there to expedite this process. I've lost patience for the old school method.
  5. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
    these cooling systems are not that complicated . pretty much post # 3 should do it . you may have to check and fill through 2 heat / cool cycles . there are no cross over tubes or small little passages in the heads and block for air to get trapped . todays cars have more aluminum parts ( like block and heads ) that require more cooling than cast iorn .
  6. maxpsi
    610
    Jul 10, 2007
    Alabama
    Maybe my water pump is bad. My bottom hose never got warm.
  7. qn60e6
    qn60e6 Veteran Member
    341
    Feb 6, 2008
    copperas cove, texas
    reversed flow water pump?
  8. maxpsi
    610
    Jul 10, 2007
    Alabama
    Then it would be pushing coolant up past the thermostat, through the upper radiator hose, and mostly likely surging coolant out of the radiator fill port on top of the radiator?
  9. BonzoHansen
    19,618
    889
    Jun 1, 2005
    Scott from Hamilton, NJ
    works for me every time, no mess....
  10. Dave Nelson
    Dave Nelson Veteran Member
    4,556
    2,661
    Dec 19, 2003
    Vineland N.J USA
    Never saw that Scott, where did you get it?
