How to Bleed Coolant
Discussion in 'Troubleshooting & Diagnosis' started by motor60, Nov 18, 2011.
  1. maxpsi
    maxpsi Veteran Member
    610
    Jul 10, 2007
    Alabama
    I've got one. I don't think my water pump is working properly. The thermostat is opening and the coolant temp is right at 165, but the lower radiator hose is cold and I see no water circulating through the radiator. If I grip the lower hose, I can feel a rhythmic thud. Maybe it's coming from the impeller?
  2. global warmer
    global warmer Veteran Member
    494
    Apr 1, 2010
    Saratoga Springs NY
    I was always told to put the fan on high heat all the way up run the car with the cap off until it comes up to temp
  3. COPO
    18,440
    1,076
    Amazon prices vary.
    Advance Auto
  4. Gary S
    22,797
    937
    Is the need to bleed coolant really a problem?
    I've always filled the engine and run it until the thermostat opens and I can feel the upper hose warm and flowing with the radiator cap off.
    Then, I shut the engine off and top off the radiator, cap it, and I'm done.
    This has always worked for me with no problems with air in the system.
  5. CorkyE
    10,547
    551
    No kidding. Sounds like we need a SOP written on how to burp a SBC... :confused:
  6. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    Yes! There is and I have one. Its from Snap On and requires compressed air. It was designed for newer cars where the radiator or filler neck is actually lower than the highest point of the cooling system. Hondas and Toyotas are mostly like these.
    I have not seen if anyone has copied this at a cheaper price yet...
  7. Joekool
    Joekool Veteran Member
    5,921
    35
    Feb 4, 2002
    Hollister CA USA
    SBC are easy to burp, BBC can be a pain, the bypass BBC's have on top of the water pump can trap air and even with an open t-stat you might not get all the air out the first or 2nd attempts.
