?how to lower water level in block
Discussion in 'Troubleshooting & Diagnosis' started by Chuck71RS, Jan 18, 2017.
  1. Chuck71RS
    1,482
    187
    Nov 24, 2012
    Houston, Texas
    Without removing the block drain plug, can the water level in the block be lowered below the level of the water temperature sensor? (Looking to remove the senor).
  2. BigBlock73
    2,046
    61
    Jul 10, 2002
    Accord,New York
    Draining the radiator should drain most of the block as well
  3. fbody_mike
    fbody_mike Veteran Member
    972
    Mar 24, 2009
    San Gabriel Valley, California
    Yeah, I don't like disturbing those drain plugs either, it always feels like I am tempting a leak or stripped threads. I just open the drain on the radiator and let it all pour out like was mentioned above. I would just add that using a jack to raise the rear will also help to empty the block.
  4. Green hornet
    Green hornet Veteran Member
    1,709
    283
    Oct 11, 2015
    North Bay, CA
    Not sure what year car yours is and how much room you have around the sender / engine compartment but I have replaced mine in my 70 without draining the coolant at all. You have to have everything ready in front of you. As you pull the old sender plug the hole with a finger at the same time. Grab the new sender remove finger and install. You have to be quick but I did it and lost less that a quart of fluid. Beats draining the system and refilling plus the mess associated with that. Hope this helps.
  5. camarolife78
    camarolife78 Veteran Member
    547
    Jul 22, 2014
    Gardner, KS
    This is how I do it as well!
  6. tom3
    tom3 Veteran Member
    12,018
    345
    Aug 1, 1999
    ohio
    And pinch off the line to the puke tank, helps to lock the system when no air can get in.
