How to remove bolts from 3 piece spoiler
Discussion in 'Tips 'n' Tricks Topic' started by InfinitR, Jul 24, 2015.
  1. InfinitR
    InfinitR Member
    71
    Jun 13, 2015
    CA
    This may be obvious to some people but I was trying to figure out how to remove the bolts from the 3 piece spoiler to mock it up on my rear end. Hopefully this helps someone.
    Take two nuts and thread them both onto the bolt. Try not to thread the bottom nut all the way down so that it is easy to remove later.
    Tighten the top nut firmly against the bottom nut. You can now use an open wrench on the bottom nut to loosen the bolt.
    Once removed, you can remove the nuts from the bolt.
    Cheers!
  2. phat80
    phat80 Veteran Member
    992
    Jan 4, 2013
    Victoria BC
    thanks
    Good tip. Like you say, obvious to some...new idea to others (like me)
  3. InfinitR
    InfinitR Member
    71
    Jun 13, 2015
    CA
  4. hogg
    hogg Veteran Member
    3,126
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    aluminum foil can be your friend , Heave duty ,long enought to go from one end to the other, put on the spoller ,shape to fit ,remove and pit to car,,, Maybe
  5. badazz81z28
    14,185
    110
    Las Vegas, NV
    Good tip, just your the SA of others, they do have tools that remove studs
  6. InfinitR
    InfinitR Member
    71
    Jun 13, 2015
    CA
    Right on. They came out pretty easy this way. BTW, I tried the aluminum foil but it didn't work well for me. Once I test fitted the parts, I traced an outline on the car and ended up using clay to press the parts into. That worked very well for marking the holes.
  7. 1dirtyz
    1dirtyz Veteran Member
    115
    Oct 2, 2011
    Riyadh , saudi arabia
    where can I get the spoiler bolts?
  8. phat80
    992
    Jan 4, 2013
    Victoria BC
    Ttt
    Just the information I needed today. Forgot about this little pearl of wisdom.
    Thanks again.
