How to remove decal
Discussion in 'Tips 'n' Tricks Topic' started by 1972original, Feb 13, 2019.
  1. 1972original
    1972original Member
    59
    Oct 30, 2018
    I have a radiator cover with original stickers that is the wrong cover for my car. I would like to transfer one of the stickers to my my radiator cover to replace one that is missing. Any suggestions on how to try and remove it? I don’t want to use a reproduction. Thanks
  2. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    739
    63
    Aug 14, 2008
    Texas
    I have no experience in trying to remove a 47 year old sticker, however, on other projects, - I have had good luck lightly using a hair dryer to warm up the glue and then gently peeling the sticker back while using a razor blade to kind of cut/scrape the glue loose from the object. On the radiator plate, I would try and get the underside of the metal fairly warm, then use the blow dryer lightly on the top to warm the sticker. In my experience, if you attempt it while cold, it will tear or break, and I would steer clear from any chemicals as they may damage the paper.
    Good Luck !
  3. 1972original
    1972original Member
    59
    Oct 30, 2018
    Thanks
  4. EVILFACE
    EVILFACE Veteran Member
    141
    32
    Sep 6, 2013
    Yukon, OK
    Heat gun, goo gone and fishing line.
  5. Zspoiler
    Zspoiler Veteran Member
    3,312
    273
    May 6, 2012
    Federal Way, Washington
    Hot soapy water using Dawn dishwasher detergent and a hairdryer and a razor blade,
  6. ZEN357
    ZEN357 Veteran Member
    384
    70
    Feb 12, 2018
    Heat gun is what I would use. I doubt you will be able to save the sticker.
  7. djorgensen3
    djorgensen3 Veteran Member
    492
    52
    Oct 15, 2009
    Peoria, Az
    Somebody out there might make a reproduction sticker.
  8. bodymanbill
    bodymanbill Veteran Member
    1,339
    726
    Feb 1, 2007
    South Park Pa
    image.jpg Camaro Central sells exact reproductions, only difference is the coolant sticker should have rounded corners, didn't notice till i put mine on or I would have cut them.
  9. 1972original
    1972original Member
    59
    Oct 30, 2018
    Thanks I don’t want to go with a reproduction as I am trying to keep all parts original. My one sticker is original as I bought the car in Oct 1971.
  10. BillyDean7173
    BillyDean7173 Veteran Member
    1,697
    363
    May 21, 2014
    Hutto, TX
    ^Let us know if you're able to save it and what method/tools you used.
