How to Roll rear wheel well lip
Discussion in 'Body Restoration' started by dingo0722, May 4, 2010.
  1. dingo0722
    dingo0722 Member
    82
    Jun 8, 2009
    Medford,MA
    I need to roll up or trim my rear quarter well lip. I've seen the tool from eastwood, but was wondering if there was a less expensive way to do a clean job
  2. dingo0722
    dingo0722 Member
    82
    Jun 8, 2009
    Medford,MA
    really! what is the technique? Did you heat the surface to prevent paint cracking?
  3. Twisted_Metal
    25,163
    254
    But don't use one signed by Babe Ruth. ;)
  4. CorkyE
    8,695
    119
    Yep, use a bat. Just put it between tire and lip then roll.
    Swerven could have told you that, but he's probably trying to swim out all the rain they've had in the past couple days... :)
  5. dingo0722
    dingo0722 Member
    82
    Jun 8, 2009
    Medford,MA
    well I will just have to give that a try.
  6. 1981paul
    1981paul Moderator Staff Member
  7. dingo0722
    dingo0722 Member
    82
    Jun 8, 2009
    Medford,MA
    theres a business for everything
  8. ATM
    ATM Veteran Member Lifetime Gold Member
    2,264
    Oct 10, 2009
    Morris, Illinois
    Let me clarify: When you say roll, you mean roll the car? Which would in turn roll the bat and flatten the lip? I'm going to be looking into this too, figured now would be the ideal time while the thing is getting restored and then when paint is on and I want to do it later it won't be an issue.
  9. ATM
    2,264
    Oct 10, 2009
    Morris, Illinois
    And slowly increase pressure. Sounds like a job for tomorrow! Thanks.
  10. 74zorro
    74zorro Veteran Member
    166
    Nov 16, 2008
    norcal
    if its a camaro thats worth money just get the right offset wheel 4.5 backspace. i put a 15x10 wheel with 10.5w slick and it fit fine.
