How to set up pick up tube oil pump 350 Lt1 oil pan
Discussion in 'Engine Topic' started by 70RSZ28hugger, Dec 4, 2019.
  1. 70RSZ28hugger
    70RSZ28hugger Member
    77
    Nov 30, 2006
    San francisco bay area
  2. flht99b
    flht99b Veteran Member
    276
    45
    Nov 28, 2014
    Knoxville, TN
    First you are going to need to straighten the sump part of the pan. 3/8" to 1/2" from bottom of oil pump pickup to pan is where I set them.
  3. 70RSZ28hugger
    77
    Nov 30, 2006
    Sorry wrong pan
  4. 70RSZ28hugger
    77
    Nov 30, 2006
  5. Plater Tom
    Plater Tom Veteran Member
    1,394
    24
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    Is that pan coated with something on the inside? Plater Tom
  6. 70lt1z28
    3,431
    682
    Oct 3, 1999
    Beavercreek, Ohio, USA
    If its primer it needs to come off.
  7. budro6968
    budro6968 Veteran Member
    3,285
    528
    Apr 2, 2016
    Jax Florida
    Use modeling clay in the pan. Button up and the take off to check the clearance.
