How to trace a short
Discussion in 'Electrical Systems' started by Aceshigh, Jun 13, 2007.
  1. 78LT383
    78LT383 Veteran Member Lifetime Gold Member
    1,779
    Jul 12, 2005
    Princeville, IL USA
    Great writeup, Aces!
    Two other things to consider when I've chased similar demons:
    1) Don't forget those things you've added that connect to the battery all the time but may not go through your fuse panel, like radio memory wires, amplifiers, and MSD boxes. I've found excessive drains from each of these things in some cases. The MSD one had me stumped for quite a while one time.
    2) Don't use heater hose, fuel hose, etc. as an electrical insulator. These have a lot of lampblack in them, which is rich in carbon and is not a very good insulator. I thought I was really clever using it to insulate a battery cable one time but later discovered that with a meter I could actually measure some continuity from one point in a hose to another! Hose is great as a protecting cover over wire against abrasion, but the insulation must be intact under the hose.
  2. earlysecond
    earlysecond Veteran Member
    5,618
    Aug 9, 2002
    Altoona, PA
    Thanks for making this a stickie. . .it was easy to find and saved me from asking AGAIN. . .that is the whole point of a stickie is it not??- haha
  3. earlysecond
    5,618
    Aug 9, 2002
    Altoona, PA
    My thanks was premature.
    If you set the meter to measure volts and there is no draw, should it read 0 volts?
    Secondly, I was never able to set the meter to show anything but 0.00 when set to measure milliamps DC the three dots . . . with a _____ under it.
    What am I doing wrong, the battery went complelty flat!
    Thanks in Advance,
  4. Fbird
    3,861
    593
    Feb 12, 2011
    atlanta, ga
    Yes they do...in fact in a pinch I have actually used a piece of fuel line as a plug wire.:eek:
    1 hellofa light show in the dark:eek: .....but i made it home.:cool:
  5. FlaJunkie
    6,247
    183
    Mar 24, 2001
    Rockledge, Florida
    If you have zero draw from a fully charged battery, and the battery dies, there is an internal short inside the battery.
    That is, IF:
    You connected the device correctly and it is functioning correctly.
  6. clay's70
    clay's70 Moderator Staff Member Lifetime Gold Member
    2,121
    60
    May 3, 2008
    Chesterfield, VA (Richmond)
    I have a short I am trying to find. I am getting continunity between the
    Batt. stud on the alt. and the alt. case which of course
    bolts to the block and goes to ground!
    Should this be happening??
  7. 78LT383
    1,779
    Jul 12, 2005
    Princeville, IL USA
    No, it shouldn't. The diodes are probably shorted, it used to happen a lot more than it does on modern cars.
    The easiest way to confirm is to pull it off and have it tested at your local parts store. You can take your meter to compare the measurements you made to the same measurements on a rebuilt one.
  8. FlaJunkie
    6,247
    183
    Mar 24, 2001
    Rockledge, Florida
    I just re-read this post and saw this...LMAO! :D
  9. clay's70
    2,121
    60
    May 3, 2008
    Replaced the diode and the reg. in the alt.
    and all is good. I also went to the junk yard
    and picked up a spare alt.
  10. 78LT383
    1,779
    Jul 12, 2005
    Princeville, IL USA
    Good deal!
