How wide of a tire can a 15x7 rim take
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by prayers1, Mar 27, 2010.
  1. prayers1
    prayers1 Member
    46
    Mar 13, 2010
    Springdale, AR
    Whats the widest tire you can put on a 15x7 Z28 rim with a stock 1972suspension. Thank you for your thoughts.
  2. BondoSpecial
    8,698
    Sep 20, 2004
    Southern Maryland
    Are you going for looks or performance? A 255/60/15 on a 15x7 is really pushing it. I have run BFG 255/60/15s on 15x7s and the tires do not wear evenly and the sidewall flex was pretty excessive. A 15x7 is not really a good wheel size to be trying to fit wide tires on, it's just not a wide wheel to start off with.
  3. prayers1
    prayers1 Member
    46
    Mar 13, 2010
    Springdale, AR
    Going for looks. I like a wide looking tire in the rear. Can't run with the big dogs now, on a budget. Would like to get 17's one day, but that will be a while. What about the front as well?
  4. BondoSpecial
    8,698
    Sep 20, 2004
    Southern Maryland
    255/60/15 is what I would (begrudgingly) recommend then. That is the absolute max I would put on a 15x7 if someone had me mount it
  5. masparks
    masparks Veteran Member Lifetime Gold Member
    1,594
    Nov 7, 2006
    Gas, Kansas
    I run 255's on the back of my car with 15" z rims with no problems at all. 245's in the front
  6. retorq
    retorq Veteran Member
    4,920
    May 13, 2003
    Kingman, AZ
    I have a 31x10.5 on a 15x7 rim. :D
  7. muscl car
    i'm running 28-9.0/15 hoosier racing slicks mounted on a set 15x7 corvette rally wheels
  8. prayers1
    prayers1 Member
    46
    Mar 13, 2010
    Springdale, AR
    Thanks everyone for your input! John
  9. masparks
    1,594
    Nov 7, 2006
    Gas, Kansas
    Hey once you put the 255's on the back!! You'll be wanting to go to an 8" rim and 275's or bigger!:crazy:
  10. dcozzi
    dcozzi Veteran Member
    2,171
    29
    May 1, 2002
    Phoenix, AZ
    I ran 265/50s on the stock rally wheels. On all 4 corners. Worked pretty well but there was a lot of sidewall.
