Hydraulic Flat Tappet Question
Discussion in 'Engine Topic' started by CoastieJoe, Jun 4, 2019.
  1. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    I am currently measuring for pushrod length on an old 350 that I am rebuilding. I am reusing the hydraulic flat tappet lifter that were in it from a previous rebuild and noticed that the exhaust lifter is very soft and compresses very easy when trying to measure the push rod length. just screwing down the rocker nut compresses the lifter. all the other lifters seem fine except this one. I'm thinking maybe I have to fill it up with oil ? but I've never done this to a lifter before?
  2. Cardinal
    8,281
    33
    Jun 22, 2003
    Endicott, NY
    Here's how I was taught: cut the top off a clean gallon milk jug. Put all the lifters standing up in the jug and put new fresh oil in there to over the top of them. Take a pushrod and push each lifter's plunger down and let it up until NO air bubbles come out of the. They are now primed.
    NOTE: make sure you use assembly lube on all the cam's journals and lobes, on each end of the pushrods, on the rocker balls, tip, and pocket where the pushrod goes into!
    CoastieJoe likes this.
  3. Cardinal
    8,281
    33
    Jun 22, 2003
    Endicott, NY
    I sell a product called an Adjust-A-Cover. I have one for standard small block cylinder heads (a tall valve cover and a short/standard height valve cover), and center bolt heads valve cover.
    http://nastyz28.com/threads/new-standard-height-adjust-a-covers.318463/#post-3632147
    They all come with 8 knockout plugs and directions.
    They are all $60 plus shipping and come with directions on how to adjust SBC hydraulic lifters with the engine running.
    PM me if you are interested in one.
    Standard Height SBC Adjust-A-Cover
    Centerbolt valve cover.
    Tall valve cover.
  4. dave@ztech
    3,482
    715
    Mar 27, 2016
    NY
    I hope you kept the lifters is order, as they need to go back into the same place you removed them from, or you will be doing that job again, with a new cam and lifters
  5. CorkyE
    10,402
    484
    What's said above, and you can put new lifters on an old cam, but not the other way around. Why are you measuring for pushrod length? Unless you're installing something in the valve train that changes the geometry, stock pushrods will work fine. The stamped steel rockers don't require as precise setup that a roller tip rocker does.
  6. Chevyforever
    Chevyforever Veteran Member
    647
    77
    Jan 4, 2011
    Is the gold valve cover painted or is it actually a gold anodized cover ?
  7. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    thanks for all the replies guys. The lifters are still all in order and the rockers are roller rockers. I am not trying to get new ones I'm just double checking all the measurements since I took it out a few weeks ago since it was supposedly rebuilt before I bought it.
    dave@ztech likes this.
  8. G72Zed
    G72Zed Veteran Member
    1,202
    280
    Sep 8, 2015
    I would use the stock (length) push rods unless the block has been heavily decked, and/or the heads heavily decked/rolled or used taller valves w/thick gaskets. As long as the lifter plunger location is within spec.
    A few ways to interpret what is the "best" length PR to use, ex: tip placement, scrub pattern width, oil hole timing, mid lift, or max lift @ retainer regardless of the other data points, or all data points combined.
  9. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    So after trying to pump the lifter to fill it with oil to minimize the amount of movement when measuring I noticed all the other lifters don't move a budge. ? Are they shot or are they not suppose to move under a grown man's weight? Thanks
