I.D. Help
Discussion in 'Engine Topic' started by Oldskool62, Oct 7, 2017.
  1. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Hello All.
    The 78 Camaro I purchased came out of the factory with a 305. At some stage it has been changed to a 350. The ID stamped on the front of the engine near the water pump is either VM8031JW or V118031JW. I have searched and cannot make any sense of the number.
    Cheers
  2. hogg
    hogg Veteran Member
    3,168
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    Could it possible be, I w, 69 350.. check your date code on back of block and heads it you don't thank thank they been changed.
  3. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Thanks I will check it out
  4. Mwilson
    Mwilson Veteran Member
    18,560
    126
    Sep 14, 2004
    Raleigh / Holly Springs, NC
    whats the suffix code?
  5. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    JW
  6. Mwilson
    18,560
    126
    Sep 14, 2004
    thats what I thought I cant find a JW anywhere
  7. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    And there lies my issue. I'll have to go down the block number path
  8. Mwilson
    18,560
    126
    Sep 14, 2004
    is the block in the car?
  9. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Yes it's still in the car
  10. tom3
    tom3 Veteran Member
    12,246
    416
    Aug 1, 1999
    ohio
    Maybe a corporate small block from an BOP car? Only J* suffix I see is for a 64 Chevelle with 327 and those don't go to the W second digit, maybe a police package? TW might be a truck engine? Odd one there.
