I have a GM Alum Intake.. Can u decode?
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by Nitro, Feb 12, 2000.
  1. Nitro
    Nitro Veteran Member
    147
    Jul 1, 1999
    N.S Canada
    I have an intake off a 74 vette.. Can anyone decode these numbers?
    14014432
    GMCFM
    Any help would be appreciate.. [​IMG]
  2. Doug G
    Doug G Veteran Member
    354
    Nov 27, 1999
    Talking Rock, Ga.
    I had one of those in my shop, it was an early '80's EGR aluminum intake. I traded it for a set of buckets for a ' 67 Chevelle! Good trade if I do say so myself!
  3. Nitro
    147
    Jul 1, 1999
    N.S Canada
    So your saying this intake is Garbage?? I thought Alum Intake were rare on Gm motors?
    Every 350cid I've seen had a cast iron intake
    on them... Maybe I lived a sheltered life..
    I don't know.. Thanks for the input anyway [​IMG]
  4. patgizz
    patgizz Moderator Lifetime Gold Member
    12,737
    Apr 10, 1999
    Cleveland
    theyre not junk by any means. its a really nice intake to use especially on a emissions motor. my uncle runs one on a 357ci BEAST. plus its pretty low profile so you dont have to worry about hood clearance.
  5. Doug G
    354
    Nov 27, 1999
    Talking Rock, Ga.
    I'm not saying it's junk, I said I traded it for a set of seats.The intake will bring $75 tops at a swap meet, the seats I sold for $250, a difference of $175. What do you think, pretty good trade, eh? [​IMG]
    These are the same intakes that came out on 305 H.O. engines, in Monte's, Z28's ,'Vettes, etc. and if you need EGR , they are good. They are plentiful down here. I get more replies for aftermarket ones, or rare factory ones, but every once in a while , someone wants one of these. I have 2 Torkers for a small block, and many other aluminum ones (Factory hi-po ones!)for B/B and S/B both.
    [This message has been edited by Doug G (edited 02-23-2000).]
  6. Gary S
    20,480
    144
    An intake's worth is determined by its casting shape more than the material it is made of.
    Aluminum has the advantage of weighing about half as much as cast iron.
    I have a factory aluminum intake on my 85 Caprice 305. In fact, all 83-85 Caprice (and probably many more years) 305s had aluminum intakes. There is nothing wrong with them, they just are no better than iron intakes of the same casting would be.
    I sold my 2 extra Caprice aluminum intakes at a swap meet last summer for $15 each.
    I still have a factory aluminum 2bbl intake from an earlier Caprice that I have not even tried to unload.
    If you live where emissions is an issue, use these intakes. If emissions don't matter, I personally won't use any EGR intake.
