I purchased the OER RS conversion kit.. it sucks... alternatives I have found.
Discussion in 'Body Restoration' started by jkhall, Mar 23, 2018.
  1. McCune
    McCune Veteran Member
    1,105
    203
    Aug 22, 2015
    st.george utah
    BillyDean7173 likes this.
  2. jkhall
    jkhall Member
    96
    11
    Dec 5, 2017
    Yes it was a complete kit, upper and lower valances, support braces, bumpers, nose cone, etc. None of them lined up to the others. I got the upper and lower to finaly bang and bend into place with minor cut and weld. Its just pathetic. The upper valance was 1/2 in to wide. I could go on and on. worst sheet metal I ever saw.
    I can at least work with fiberglass and add or take off space relatively fast and easily compare to metal work. And those that would not run fiberglass body parts i am perplexed. there exotic cars that are raced over 180MPH that are fiberglass with metal braces inside just like the fiberglass fenders and front pieces you can get for the camaro. Hell the Corvette for the longest time had been fiberglass as well. To each their own but reinforced fiberglass body parts have been part of the automotive world for 80yrs now. Is it the best way for everything, no. but Steel is not the best way for 'everything' either.
  3. jkhall
    jkhall Member
    96
    11
    Dec 5, 2017
    Exactly. in your pic I see how the grey OER stands higher than the factory white one. I keep wondering if I heat up the OER Polly nose if I can form it correctly.
  4. jkhall
    jkhall Member
    96
    11
    Dec 5, 2017
    have you thought about getting a 3d model image of it made? then I could take it to a 3d builder and have one made with real specs.
  5. McCune
    1,105
    203
    Aug 22, 2015
    st.george utah
    Thought about it, probably won't do it. I don't have a problem with the strength of fiberglass, I just don't like the looks of it on a early second gen.
  6. CamarosRus
    CamarosRus Veteran Member
    8,485
    140
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Box1.Label..JPG RSNose.RightBottomCorner.NOS.70.73Camaro.jpg RSNose1.BottomCenter.NOS.70.73Camaro.jpg RSNose2.LeftBottomCorner.NOS.70.73Camaro.jpg RSNose3.RearViewBottomCenter.NOS.70.73Camaro.jpg RSNose4.RearViewLeft.NOS.70.73Camaro.jpg RSNose5.RearViewRight.NOS.70.73Camaro.jpg
  7. jkhall
    jkhall Member
    96
    11
    Dec 5, 2017
  8. DrPepper
    DrPepper Veteran Member
    204
    44
    Aug 29, 2017
    Central VA
    You say the header panel, upper valance, was 1/2" too wide. What was the measurement? And do you know what the OE measurement should be??
    I'm having problems aligning a total repop RS front clip. The fenders & hood are Goodmark and everything else is pretty much OER.
    I think my OER header is too wide causing my fenders to pinch the hood at the windshield.
    AND, I totally agree that OER sheet metal is junk.
  9. jkhall
    jkhall Member
    96
    11
    Dec 5, 2017
    I dont know the width it should be... but I do know there is an extra 1/4 inch gap between fender and hood on both sides at the header causing an unsightly front end. :(
  10. secondgenaddict
    secondgenaddict Veteran Member
    342
    134
    Dec 29, 2012
    Upstate South Carolina
    Flexible material can be added to the "new" nose or to an old one.
    I added 1/2 inch to a OER repro urethane front bumper for a 69 Camaro using 3M automix flexible repair material - I also did deformation stress tests bending the added area against itself to ensure a reliable and DURABLE finished product.
    1. clean the OER product extremely well using wax oil grease remover
    2. Use a rasp file to rough up the area which you are going to build up. _
    3. Clean again,
    4. Use some masking tape to build a "dam" in the area you wish to build up,
    5. Automix repair and layer it until the damaged area is raised, then file and and smooth...
    6. File
    7. check
    8. Fill
    After getting the areas filled shaped smoothed, then prime with Spies Hecker flexible parts primer and shoot your clear with a flex additive.
