I purchased the OER RS conversion kit.. it sucks... alternatives I have found.
Discussion in 'Body Restoration' started by jkhall, Mar 23, 2018.
  1. smokeatr23
    smokeatr23 Veteran Member
    232
    10
    Dec 24, 2014
    United States
    What did you decide on?
  2. Madcow63
    Madcow63 Member
    49
    Jun 14, 2009
    Toledo Ohio
    I bought the kit as well. I don’t think the nose is as much the problem as the upper valance. Seems the point at the center is too high, and the bend is not crisp enough
  3. GoldenOne7710
    4,871
    444
    Jun 23, 2004
    Athens, GA
    Sounds like the parts are not consistent in their dimensions from customer to customer. That's just bad.
  4. badazz81z28
    17,093
    546
    Las Vegas, NV
    There should be some stringent quality metrics before it can have the GM sticker on it....it’s all marketing BS!
    mrfleet12 and Smokey15 like this.
  5. COPO
    18,005
    830
    If I needed a RS front end, I would hunt down a RS parts car unless you come across a complete car for cheap money. There’s got to be 6 bangers out there.
  6. McCune
    McCune Veteran Member
    1,071
    191
    Aug 22, 2015
    st.george utah
    IMG_7594.jpg IMG_6578.JPG I didn't convert my car to a RS but I did replace the parts with OEM parts because the original purple car had been filled with bondo and had a 70/72 urethane nose so the 73 crash brackets could not attach properly. The way I figure, you can either pay a body guy a ton of money to fix aftermarket crap or you can drop some coin on real parts if you can find them, they are out there if you look.
  7. TommyRS70
    TommyRS70 Veteran Member
    1,200
    102
    Jan 31, 2004
    KY
    I don't know where you are on the lower valance at this point but the RS nose will not fit on a standard lower valance shown in your pic. Seems to be the main reason for fitment problems.
  8. McCune
    1,071
    191
    Aug 22, 2015
    st.george utah
    Right the aftermarket don't fit the bottom, it has at least 1/2 " gap. IMG_7420.jpg
