Ideas for a Post-Restoration Road Test Checklist
Discussion in 'The BS Topic' started by CDesperado, Dec 23, 2019.
  1. Happy_Dan
    Happy_Dan Veteran Member
    1,012
    219
    Sep 13, 2013
    New Boston, NH
    I would agree with the above. Check all suspension parts for torque. After you get some confidence and drive it a bit, re torque all nuts and bolts.
  2. xten
    xten Veteran Member
    3,216
    2,011
    Sep 24, 2014
    Pittsburgh, Pa.
    I would "nut and bolt" EVERYTHING before I drove it. I sometimes get distracted (phone call, lunch etc) when I'm in the middle of something important.
  3. dcozzi
    dcozzi Veteran Member
    3,274
    522
    May 1, 2002
    Phoenix, AZ
    It was already said but...fire extinguisher. Always in car.
    I would add check all fasteners in your steering components from steering wheel to the front rims.
    Brakes. Make sure they grab before even taking car off the stands.
    Carburetor. Make sure return spring works and there are two of them. Make linkage does not catch on anything like the air cleaner lid.
  4. dcozzi
    3,274
    522
    May 1, 2002
    Phoenix, AZ
    During the build, I started to leave lists attached to the car in areas I was working, checking stuff off as I go.
    Sometimes, I use wide blue tape with sharpie notes attached to the outside of the car.
  5. berg2695
    berg2695 Veteran Member
    297
    59
    Nov 13, 2011
    AUBURN, WA
    I like to use a paint pen to mark fasteners that have been torqued, like manufacturers do. It seems I can forget within 30 seconds! o_O
    xten and gramps like this.
  6. Twisted_Metal
    27,308
    1,122
    Belts.
    Check them for proper tension before and after the test drives.
  7. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    748
    66
    Aug 14, 2008
    Texas
    CDesperado, It's always good to be prepared, but try not to overthink it. It sounds like you are on the right track. Certainly when working on things over time, some things like lubing the new ball joints, or filling the rear end can get left behind, but this should be a pleasurable drive, not a teeth gritting "what's going to go wrong" event. I always start slowly and stay within pushing distance, then branch out further but within the "I can tow this home with a chain" radius. Then when all is well, your ready to venture out to the $120 tow truck hookup range. ;)
    Relax, enjoy and take it easy on the first few outings. That's what it's all about. Oh, and check the u-bolts and lube on your U-Joints. Don't want to lose a driveshaft.
    Have Fun !
    (and lets see some pics)
  8. budro6968
    budro6968 Veteran Member
    3,524
    619
    Apr 2, 2016
    Jax Florida
    Drive shaft bolts tight. I was in a car that a buddy just put a trans in. Got about a mile from the shop. Boom rattle rattle. Drive shaft rolling down the road. LOL.
  9. grzewnicki
    3,461
    185
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I did the short drive, short drive, short drive, then longer drive, longer drive, even longer drive when I finished mine, looking car over after each one, retorquing suspension components, checking engine mounts and trans to eng bolts, trans mounts, after the short drives. Stayed off freeways for a bit till I felt comfortable that I did everything right or fixed anything I over looked. I still always make sure I have a cell phone with me when I drive the Z, something I don't do jumping in the Explorer to run to the store.
  10. CDesperado
    3,590
    79
    Oct 1, 2004
    Dallas Texas
    Unfortunately, I am squarely in the teeth-gritting phase right now. I feel like I am just chasing problems around the car right now, which would be fine, but I still have less than 10 miles on it. I've had a number of issues that I've had to identify and fix.
    Btw... the lube on the ball joints and checking the U-joint are great suggestions.
