Idle when timing 70z28 LT1
Discussion in 'Troubleshooting & Diagnosis' started by 70RSZ28CAMARO, Jun 2, 2019.
  1. 70RSZ28CAMARO
    70RSZ28CAMARO Member
    51
    Dec 19, 2003
    Long Island, NY
    Hey guys I just want to confirm what the ideal rpm setting should be when I do ignition timing on my car. Is it the recommended spec which I think is 750 RPM or should it be my at my normal idle speed which I have above that. appreciate any help that you can provide
    Thanks
  2. dave@ztech
    3,253
    654
    Mar 27, 2016
    NY
    If you have vacuum advance, if it is idling too high, the advance may start coming on, I am sure someone with more experience will chime in shortly
  3. bourbon_scotch
    2,274
    105
    Jan 10, 2003
    USA
    It should always be whatever the manufacturer states it is on the tune-up decal in the engine compartment. Those are the numbers tested for that engine. If something has changed on your engine, like maybe you upgraded your distributor from points, those numbers aren't going to mean much.
  4. COPO
    17,534
    615
  5. CorkyE
    10,139
    392
    Is the engine completely factory stock? If so, follow what COPO posted.
  6. badazz81z28
    16,291
    393
    Las Vegas, NV
    Yeah, too many things unknown variables here. If it’s an auto, the RPM will drop when you put it in gear. 800 for auto/750 for manual is fine. Honestly even 800 for a manual is fine. There is idle timing and max timing all dictated by the springs in the distributor.
    Is the engine all stock?
  7. 70RSZ28CAMARO
    51
    Dec 19, 2003
    Long Island, NY
    My setup is the original LT1, 82,000 miles, hooker headers, 2 1/2 exhaust and msd streetfire distributer.
    Thanks
  8. 70RSZ28CAMARO
    51
    Dec 19, 2003
    Long Island, NY
    One more question, after I timed the engine at 8degrees btdc at 750rpm, I’m noticing an intermittent pop at wot in 3rd or 4th gear. Otherwise it’s running strong. Sounds like unburnt fuel. Maybe timing ? What do you guys think.
    Thanks
  9. COPO
    17,534
    615
    8* at idle is too low, shoot for 12-14 initial. If you have a back dial light shoot for 36* total with vacuum advance plugged.
    70lt1z28 likes this.
  10. 70RSZ28CAMARO
    51
    Dec 19, 2003
    Long Island, NY
    I’ll try that, but my mechanic previously had me plug the vacuum canister on the distributer permanently. Does it need to be reinstalled?
