I'm ready to surrender to the LS world!
Discussion in 'High Tech Retrofits' started by dougs79Z28, May 29, 2012.
  1. dougs79Z28
    dougs79Z28 Veteran Member Lifetime Gold Member
    355
    Oct 26, 2010
    Nashville, TN
    zzzzzz......still waiting for the cam vvt delete kit.
    Transmission question. I have a free TH350 transmission to use. What OD transmissions could I use and still keep the factory shifter (using the shiftworks plate)? 200r4 the best option?
  2. camarochevy1970
    camarochevy1970 Veteran Member
    7,827
    74
    Jan 23, 2003
    Pittsburgh, PA
    I think 200-4r might be the only chance
    Also, my cam has a delivery date of tomorrow (fedex tracking finally)
  3. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    I stopped trying to find out.:( I think 200r4 is the way I'm going. Would like to get it in with the motor instead of doing it later down the road. It's just money, right? lol
  4. usmcz28
    usmcz28 Veteran Member Lifetime Gold Member
    382
    Jun 19, 2005
    Rochester, NY United States
    Why not use a 4l60 or a 4l80?
    And yes my cam took forever as well!
  5. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    Well- that's my question. Bowtie OD wants over 2k for a 200r4 with everything I need (1,300 for trans). I'm using a carb so no computer on board. Can I operate a 4l60 with a stock shifter? Rich at Bowtie said I would spend about 1k more to go with one of those for the comp and programming device. All I'm wanting is a good auto w/od that will handle about 425-50 hp.
  6. camarochevy1970
    7,827
    74
    Jan 23, 2003
    Pittsburgh, PA
    You may be able to get a stock shifter to work with a 4l but the add on computer etc. makes it more difficult then a 200
  7. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    The 200-4R only requires a torque converter lock up kit and the TV (throttle valve) cable to properly operate the transmission.
  8. usmcz28
    382
    Jun 19, 2005
    IIRC you only need to slightly modify the bracket for the 4l80/4L60 and Jake Show sells a stand alone kit for around $600.
    http://www.jakesperformance.com/4L80E_Components.html
  9. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    Looks nice! Add another $550 for speedo gear....that's one expensive tanny for my car. Wowzers!! More than I paid for the car and my LY6 with all the add on's. More I think about it- I better use the TH350 I have for now and concentrate on getting the front getting it in and running. The front drive accessories is a must and I haven't tackled that yet!
  10. dougs79Z28
    355
    Oct 26, 2010
    Nashville, TN
    Finally!!!
    Man- the lobes on my flat tappet hydraulic cam were no where near this big and flat on end! Oh mamma!!!
    Now I still am waiting on valve springs, retainers and new front cover. Get the oil pan from JJ Farmer (hopefully) and I'm ready to get down to business!
