Inconsistent blower motor fan
Discussion in 'Electrical Systems' started by 1st and goal, Aug 30, 2016.
  1. 1st and goal
    1st and goal Veteran Member
    400
    Nov 5, 2005
    Seacoast, NH
    Hi,
    My blower motor is inconsistent. Sometimes it works, sometimes not so much. When I turn the blower motor on "HI" I can feel cold air so I know the A/C is working but the air coming out of the vents feels like the blower motor is on low speed, then for whatever reason it will kick in and start working. It does the same thing without the A/C on.
    I replaced the blower motor and blower wheel a couple of years back.
    Marc
  2. Twisted_Metal
    26,990
    966
    Hi speed is controlled by the relay. Check your blower relay connections and the ones at the resistor pack.(It's the plug at the fiberglass box near the hood hinge.)
  3. 1st and goal
    400
    Nov 5, 2005
    Seacoast, NH
    Thanks, I'll check it out
  4. Dioskouori
    Dioskouori Member
    58
    Aug 5, 2016
    Deloit, IA
    Does it work on any other setting? Or is it just the "hi" setting that has stopped working?
  5. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
    To achieve any other fan speed than high for a 73 you move the temperature selection slightly past cool ( if working properly)
