Initial start of LS without full exhaust system?
Discussion in 'High Tech Retrofits' started by Goat, Jul 2, 2018.
  1. Goat
    1,891
    40
    Jun 7, 2001
    moncure, NC
    Just about done with the wiring and wanted to try and fire the engine to make sure all was hooked up correctly. Right now I just have open headers. I was going to trailer it to a place to have ss exhaust installed from the headers back after the initial start.
    But, I was re-reading the GM engine control harness instructions and it said the exhaust system must be properly sealed or the oxygen sensors may not work right. I currently have a 'start-up' tune on the ECM and was planning on a dyno tune when all was ready. I don't want to take a chance of dumping too much fuel or not enough because the sensors are not reading right.
    Is this a concern? Should I have the exhaust system finished before firing it up?
    thanks.
  2. nobreaks254
    nobreaks254 Veteran Member
    489
    8
    Jul 14, 2007
    aberdeen, SD
    If you really want to run it you could hook up 3 feet of pipe to you headers and you should be fine. That should be long enough to keep the o2 sensors happy
  3. Mike-78 Z-28
    Mike-78 Z-28 Veteran Member
    1,909
    Mar 4, 2003
    ElDorado Arkansas
    I'm going to say properly sealed means no exhaust escaping through blown or no gaskets so the O2's can read the entire mixture.. I'm sure it'll run fine just for a trip to the muffler shop.
  4. bigkat_83
    bigkat_83 Member
    31
    8
    Dec 7, 2014
    Bogart ga
    Is this a new crate engine? When I did mine I had a very hard time getting the engine oil pump primed. In the GM instructions they say to do it with the starter. I had to pump it thru one of the oil ports. Finally got it primed and then could see oil pressure with the starter.
  5. badazz81z28
    16,178
    377
    Las Vegas, NV
    I started mine with open headers. I wasn’t going to drive down the road with it like that, but I surely did start it. Good thing too because it caught issues I would have wanted to fix in the garage, not at the tuner. Such as...it wouldn’t start lol.
    The o2 sensors don’t do anything and anyways until they are hot.
  6. Goat
    1,891
    40
    Jun 7, 2001
    moncure, NC
    Thanks guys for the replies.
    Nobreaks, we just got back from a 3 week camping trip. Spent five days in South Dakota. What a beautiful place...
  7. Goat
    1,891
    40
    Jun 7, 2001
    moncure, NC
    Not a crate engine. It's been broke in already on a dyno...
  8. Knuckle Dragger
    14,457
    1,105
    Nov 2, 2002
    Waddell AZ
    Heated O2s get hot pretty quick. You'e into closed loop within seconds any more. I wouldn't hesitate to start it. The only issue I can see is if the exhaust pulse allows air to be sucked into the exhaust near the O2. If your sensors are near the open collector this might be an issue, but I doubt it will have a catastrophic effect of major over fueling.
