Initial Timing Advance Question
Discussion in 'Engine Topic' started by Brads GN, Jul 22, 2012.
  1. Brads GN
    Brads GN Veteran Member
    101
    Jun 22, 2012
    Cobourg, Ontario, Canada
    Could you guys give me a ballpark figure on what initial advance you guys have used for the Comp Cams Magnum 280H cam...and the RPM you set it at. TIA.
  2. Pfrederiksen
    Pfrederiksen Veteran Member
    609
    Feb 21, 2011
    Edmonton,Canada
    I usually shoot for 34-38 deg all in and let the initial fall where it may.
    (probly 18....ish)
    Although your combo will dictate.
    P
  3. CorkyE
    10,433
    503
    That real dependent on your distributor. Most aftermarket units will have something like 22* mechanical so 14 initial will get you to 36 total. If it's a smog era dizzy, that's a different story...
  4. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,063
    Sep 22, 2007
    Blind Bay, B.C.
    I've got mine at 20 btdc, 35 at 3000 rpm. Idles at 750 rpm. My vacuum is just under 10 in hg.
  5. REARSPROCKET
    REARSPROCKET Veteran Member
    916
    Apr 27, 2007
    Gas Fume Heaven, Coastal Northeast, USA
    Total advance timing number can depend on the head's combustion chamber, older irons like a higher number like 38-40* and newer vortec styled chambers like 32-36*.
  6. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    As already alluded to, you need to tell us which distributor you have and if you have vacuum advance connected or not. It would also be good to know how much mechanical advance your distributor has. If you don't know, you really should figure this out. All of these factors, as well as your combo, will influence the answer.
    While that is not a huge cam, it is still big enough to respond to vacuum advance at idle (or more initial without vacuum advance - depending on your combo).
    As rearsprocket said, I ran my old Comp 280H at closer to 40° total timing, with 22° mechanical advance, 18° initial, and old iron heads on my lower compression 400 sbc.
  7. Brads GN
    101
    Jun 22, 2012
    It's the original factory distributor.
  8. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    Have you changed the springs in that HEI yet? My '80's HEI didn't fully advance until after 4k RPM's (very lazy). I would suggest getting a spring kit and putting in a light and medium spring. Then, set your total timing to 36 degrees. See how it runs.
    If you are feeling bold, look into limiting the mechanical advance so you can run 18 initial, and 18 mechanical. I bet it would run even better.
  9. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    my 454 with 292h cam 18initial, 20 mechanical, 15 vacuum. will idle at 600 but I idle it up around 900-1000 so when the electric fans kick on and the alternator kicks in, it will drop to around 700 :)
  10. gingerbreadman
    gingerbreadman Veteran Member
    785
    Jun 2, 2009
    gold coast , australia
    Not the same cam but somewhat comparable.... 18 initial, 18 mechanical.Idles at 700 no vacuum advance.
