inner fender removal
Discussion in 'Body Restoration' started by phat80, Jun 30, 2013.
  1. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    my 1980 has 33 of crap in the fender wells. I want to completely remove the inner fenders to clean them properly and repaint them.
    Do I have to take the fender off in order to remove the inner?
    Thanks
  2. stroked383
    stroked383 Veteran Member Lifetime Gold Member
    764
    Jul 18, 2011
    Saugerties, NY
    No. You just need to remove a couple fender to inner fender bolts, Washer jug, coolant overflow, battery tray or charcoal canister, a few bolts under the battery tray and that's about it, the inner fenders come out with a little twisting and turning.
  3. K5JMP
    10,216
    8
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    and a few band-aids...lol;)
  4. phat80
    1,021
    13
    Jan 4, 2013
    Victoria BC
    Ttt
    Thanks kids.
    I've got to clean up the A arms and frame as well. I'll probably re-bush the front end.
    Thanks for the help, much appreciated.
  5. Ryan 79
    Ryan 79 Veteran Member Lifetime Gold Member
    3,299
    Mar 29, 1999
    Granite Falls, WA
    Take all of it and get it powdercoated. Youll be amazed at how cheap it is
  6. phat80
    1,021
    13
    Jan 4, 2013
    Victoria BC
    what a blast from the past. I just came across one of my first posts on this site when I started my "clean-up" about 6 years ago. I knew absolutely NOTHING! Here is a picture of the car in reassembly several years later after I did EVERYTHING my self including the paint. If I can do it, you can do it.
    sandiego74 likes this.
  7. CorkyE
    10,272
    430
    ^ Good on ya^ :)
  8. 71flh
    71flh Veteran Member
    990
    27
    Jun 1, 2010
    DFW
    Heh, I guess it doesn't matter now, but I think I'd take the tire off and drop the inner out that way...
  9. badazz81z28
    16,589
    438
    Las Vegas, NV
    Having done this a few time, taking the tire off is a must!
