Inner fender wells..removal Q's
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Camaro75LT, Jun 4, 2008.
  1. Camaro75LT
    Camaro75LT Masshole Staff Member Lifetime Gold Member
    6,499
    47
    May 17, 2001
    Boston-ish
    If I yank those things out, what will I need to relocate? I know the washer fluid and coolant overflow bottles are on there, but is the battery mounted to them too?
    My front tires hit the inner wells when I hit a pothole hard, and I don't have the $ for springs at the moment. figured it's a quick fix.
  2. hucks 70
    hucks 70 Veteran Member
    1,293
    Jun 4, 2004
    millstadt ill USA
    smaller tires .inner fenders make up alot of support for the front end and fenders.
  3. pete0331
    pete0331 Veteran Member
    656
    Mar 26, 2006
    Kitsap, WA
    Yes, the battery tray mounts to the front portion of the fender.
  4. Camaro75LT
    6,499
    47
    May 17, 2001
    Boston-ish
    im going with solid body mounts and SFCs, I will run a brace on each side to try and make up some of the support.
    I would go smaller tires, but like i said, i'm on a tight budget at the moment
  5. woody80z28
    5,430
    12
    Sep 8, 2004
    walton, ny usa
    The fuel return canister thing is on the driver side. I took mine out and bought a vented gas cap with no problems.
    G-braces may help. And FWIW, I've had half the bolts missing from the inner fenders without issues! haha I did just buy some clips to fix that though and from everything I've read it is a very good idea to keep them.
  6. Camaro75LT
    6,499
    47
    May 17, 2001
    Boston-ish
    After a little playing with the car, the wheels hit in the back of the fenders (toward the doors), what could be causing this?
  7. chevy-stu
    chevy-stu Veteran Member
    777
    Mar 22, 2007
    london-england
    Really badly worn bushings ?? very saggy springs.. sounds like the whole front end could do with a rebuild.. (I know it's loads of money.. !!!)
  8. Camaro75LT
    6,499
    47
    May 17, 2001
    Boston-ish
    I have a new set of control arm bushings, gotta figure out how to install them without a press.
  9. Lowend
    14,013
    153
    Mar 25, 1999
    San Jose, CA, USA
    Its really a bad idea to remove the inner fender wells.
    First - it makes a huge mess under the hood every time you drive
    Second - it does strange things to the car's aerodynamics at speed.
