Inside heater box cable bracket needed
Discussion in 'Camaros Wanted' started by 70lt1z28, Oct 26, 2018.
  1. 70lt1z28
    3,431
    682
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Does anybody have a spring they can measure for me?
  2. 70lt1z28
    3,431
    682
    Oct 3, 1999
  3. 70lt1z28
    3,431
    682
    Oct 3, 1999
  4. Budz
    3,095
    110
    Mar 17, 2002
    Ashburn, Va USA
    I just crawled under mine to look. '70 04D Norwood Z. I've had the car 20 years and never had the box out. Can't get a pic, but I can see the spring on top
  5. 70-camaro
    70-camaro Veteran Member
    2,402
    444
    Mar 25, 2010
    marietta ohio
    As I move that lever from left to right at about 3/4 of the way it does have a snap effect like it is helping. I can see the spring stretch as I move it. No way for me to measure the length though. I might be able to get a rough idea of the OD tomorrow.
  6. 70-camaro
    2,402
    444
    Mar 25, 2010
    marietta ohio
  7. 70-camaro
    2,402
    444
    Mar 25, 2010
    marietta ohio
  8. 70-camaro
    2,402
    444
    Mar 25, 2010
    marietta ohio
    No way for me to get anything up there to measure the diameter of the spring, 6 inch rule or otherwise. Looks to be 3/8 Dia.
  9. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
    1002AFB8-4521-43AF-AFAA-70A61AE3CA60.jpeg ED9A9342-1A16-46D3-9582-981BA465A576.jpeg 5F99A9AD-B178-4C56-AB7E-2BC2EDDC6212.jpeg I’m confused. What is the consensus? Should we have that bracket and spring on the heater box? Here is the box I received from a forum member and it appears as though that bracket was in place.
    Also why do I have those for holes on each side of the door where as on the heater box in this thread I don’t see those for holes?
  10. restore-z28
    restore-z28 Veteran Member
    417
    66
    Jul 4, 2010
    Vancouver, BC
    ^^^ Here is my original rebuilt heater box, car is an 05E build date. Those 4 holes should not be there...mine also has the spring, I think it might be a late addition to production as it would seem the early cars don't have the spring.
