Internal Frame Coating
Discussion in 'Body Restoration' started by mk3ricks, Jun 6, 2019.
  1. mk3ricks
    mk3ricks New Member
    19
    8
    Apr 4, 2018
    Been reading a lot about Eastwood Internal Frame Coating and I feel this is one of the better solutions I would try for hidden areas on my 75 Rally Sport, but they don't sell it in bulk. I was hoping to uses a better style applicator than a rattle can. I have to believe this product can be bought in bulk from another supplier anyone have any idea on where to get this type of product in quarts?
  2. Chuck71RS
    1,371
    152
    Nov 24, 2012
    Houston, Texas
    SEM makes an isolation product "RUST SHIELD" in quart and gallon but no info as to composition. https://www.semproducts.com/product/rust-shieldtm/28104
    I used the Eastwood Internal Frame Coating spray cans (3 maybe 4) With the 2 foot flexible tube w nozzle on the end, coated every bit of the frame interior. Gets easily through all curves. Without the flexible tube, I don't see how the areas beyond the curves can be coated
    hubedobeedo likes this.
  3. mk3ricks
    mk3ricks New Member
    19
    8
    Apr 4, 2018
    I have this in mind as an applicator for the internal frame and hidden areas .....all other areas have been treated with KBS RustSeal
    hubedobeedo and budro6968 like this.
  4. budro6968
    budro6968 Veteran Member
    3,099
    482
    Apr 2, 2016
    Jax Florida
    Where did you get that? Looks like something a Bug Exterminator would use.
  5. Jeep43
    Jeep43 Veteran Member
    1,252
    43
    Mar 30, 1999
    Connecticut
  6. Chuck71RS
    1,371
    152
    Nov 24, 2012
    Houston, Texas
    Will the nozzle produce a 360 fan (the Eastwood conical nozzle does) Wonder if the inhibitor will plug up the end? Doesn't look flexible enough to go through the side of the frame so need at least 5 feet from the front and 5 from the rear.
    Seems like a lot of expense with unproven hardware when the Eastwood is proven product and application hardware.
    Hope it works out for you. Sometimes experimenting can be gratifying
  7. mk3ricks
    mk3ricks New Member
    19
    8
    Apr 4, 2018
    The sprayer is something KBS Coating offers to apply there products, anyway I'm going to try to steer this back to the direction of the actual question.
    It's not the hardware I'm interested in but the Zinc Phosphate Sealant that prevents future corrosion. Eastwood used to have this in bulk but discontinued that product. My question is can anyone recommended a Zinc Phosphate coating in bulk (I really only need a quart)
    https://www.kbs-coatings.com/underseal-gun.html
  8. mk3ricks
    mk3ricks New Member
    19
    8
    Apr 4, 2018
    Can you please send me a link to the 5ft hose and nozzle
    Thanks Mike
  9. Chuck71RS
    1,371
    152
    Nov 24, 2012
    Houston, Texas
    Was only posting distance if coating the frame through the front and back. Don't know where the needed hose can be obtained
  10. Scott51
    Scott51 Veteran Member
    612
    69
    Jan 2, 2012
    New Zealand
    a cavity wax from Dinitrol, wurth, Noxudol, 3M, or SEM would be better and most are available in 1qt or 4.2 qt cans
