Is it supposed to be like that? (front end bolt holes)
Discussion in 'Body Restoration' started by ISRcamaro, Jan 10, 2017.
  1. ISRcamaro
    ISRcamaro Veteran Member
    439
    19
    Oct 10, 2016
    Israel
    I saw there are 2 empty holes at the front end (under radiator) that seems like the holes there were ripped off and aren't aligning.
    I guess that at some time at the car life time it suffered a hit.
    Am I right are there really bolts supposed to be there?
  2. Green hornet
    Green hornet Veteran Member
    1,027
    134
    Oct 11, 2015
    North Bay, CA
    That hole should have a bolt in it. Here is a photo of the same area on my 70. It's hard to tell but you can see the bolt on the right edge of the photo.
  3. Bandit723
    Bandit723 Veteran Member
    2,258
    262
    Oct 1, 2016
    Waupaca WI
    Should look like this
  4. jamieg285
    jamieg285 Veteran Member
    1,232
    Jul 15, 2004
    Luton, England
    +1 - there should be bolts there, the same as the front. They are unusual serrated bolts, probably because it will be impossible to get a spanner on them when the outer structure is in place.
