is the radio dead?
Discussion in 'Car Audio, Electronics & Security' started by Chuck71RS, Apr 26, 2017.
  1. Chuck71RS
    1,419
    174
    Nov 24, 2012
    Houston, Texas
    Was working while installing new gauges with key in "acc" position
    Completing the gauge install, radio did not come on when the engine started but neither did the gauges. Did not come on with key in "run" or "acc"
    With battery disconnected the radio fuse has almost 0 resistance (multi meter) so it is good
    With battery connected and radio turned on, the radio fuse in the fuse panel has voltage coming into the fuse but none coming out.
    With battery disconnected, checked resistance of the 3amp fuse just before the radio and meter shows almost 0 resistance
  2. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,063
    Sep 22, 2007
    Blind Bay, B.C.
    When you tested the voltage coming out of the fuse with the battery connected, was one test lead from the multimeter connected to a ground? Common mistake is testing from one side of a fuse to the other. Just asking.
  3. Chuck71RS
    1,419
    174
    Nov 24, 2012
    Houston, Texas
    At the fuse panel, the black probe was connected to a ground. The red probe was placed on the right side of the fuse (voltage coming in) then the left side (voltage going out). Zero voltage on the left side and 12.6 on the right side
    More concerned about the radio then the gauges
  4. Twisted_Metal
    26,944
    925
    That's exactly how I test for a blown fuse.
    Power on one side and not the other means there is no continuity within the fuse.
  5. Chuck71RS
    1,419
    174
    Nov 24, 2012
    Houston, Texas
    But with the battery disconnected fuse resistance is almost 0 ohms with one probe on one fuse end and the other probe on the other end.
    So doesn't this mean the fuse is good?
  6. Gary S
    22,409
    751
    You aren't trying to check fuse resistance with it in the circuit , are you? If you want to check resistance, pull it out first.
    Or, simply try another fuse that you know is good.
  7. Chuck71RS
    1,419
    174
    Nov 24, 2012
    Houston, Texas
    I was checking resistance with the fuse still in the fuse panel. Removed the fuse and saw it was blown. New fuse in and the radio is working fine again.
    Did not know (and still don't know why) a blow fuse tested for resistance while still in the fuse panel gives a false reading.
  8. Green hornet
    Green hornet Veteran Member
    1,675
    278
    Oct 11, 2015
    North Bay, CA
    It is easy to over think things sometimes. The easiest way to check a fuse is with a test light. The light needs work on each side of the fuse with the key on. If it doesn't it's bad. Good to hear problem is fixed.
  9. bourbon_scotch
    2,346
    122
    Jan 10, 2003
    USA
    It's because your reading from one side of the fuse through the circuit till it meets up to the other side of the fuse. If the fuse wasnt blown you would be measuring two circuits together, the one through the fuse and the other through the circuit the fuse controls.
  10. Twisted_Metal
    26,944
    925
    ^ Exactly!
