Is there anything I am Missing????
Discussion in 'High Tech Retrofits' started by Ravenous70, May 30, 2008.
  1. Ravenous70
    Ravenous70 Veteran Member
    308
    Nov 8, 2007
    DFW,TX
    So I have been sitting here feeling like a have forgotten something on my Carb'd LS1 2Gen Camaro Build. Like.......
    "Do I need a vacuum booster for my power brakes"
    "Do I have to use a manuel oil pressure gauge or can I use the factory LS1 sensor"?
    "Can my factory temp sensor work with my dash gauge"?
    "Which belt do I use for a Car without powersteering"?
    "Do I need somesort of adaptor to run a LS1 Vette Alt on my 2nd Gen Camaro's Electrical system"?
    "Will a 600cfm carb work with my cam specs until I get a 650cfm carb"?
    Specs on everything I am doing found on my Cardomain link, plus maybe there are some other things I may have forgotten.
