is this a staggered bolt starter?
Discussion in 'High Performance Modifications' started by speedfreak1000, Feb 5, 2012.
  1. speedfreak1000
    speedfreak1000 Veteran Member
    1,269
    Feb 20, 2009
    Springfield, kentucky
    sorry about the crappy pics but i was sticking my phone under the car and snapping pics.
    looks to me like its a staggered bolt pattern but before i pull the trigger on buying something i was wanting some more input. also if thats what it is what would the tooth count be on the flex plate so i get the right one.
    thanks again
    David
  2. gregs78cam
    gregs78cam Member
    51
    May 2, 2004
    Spirit Lake, ID
    yup that's it
  3. Todd80Z28
    11,489
    222
    Jun 11, 2002
    Northern VA
    David- if you're looking for a replacement, consider the early 90s S10 Vortec 4.3 starters. They're a gear reduction unit, lightweight, and a LOT cheaper than aftermarket gear reduction starters.
    Do a search here, some specifics will come up.
    EDIT- just saw Greg's suggestion in your other thread.:)
  4. 5spd540
    12,369
    13
    Sep 19, 2009
    Guyton, GA
    Thats one for sure
  5. MassD
    MassD Veteran Member
    211
    Feb 20, 2011
    NonOfYourBusiness
    I would reccomend pulling the starter sometimes blocks are drilled for both staggered and straight
