it's all the little things that add up (big block swap)
Discussion in 'The BS Topic' started by Jimmac, Feb 5, 2019.
  1. Jimmac
    Jimmac Veteran Member
    395
    71
    Dec 24, 2013
    tucson az
    it's been 3 weeks and it's almost done. got a cheap 454 a couple months back with what the seller thought was a blown head gasket. So I decided why not put it in the camaro. ordered a set of summit headers, and decided to just go for it. I have the brackets and pulley, a rpm intake, passenger car pan, pump and pickup.
    So bout with the 400 and drop in the 454.
    1. motor mounts were bad. $15
    2. need a waterpump $55
    3.belts and hoses . $50
    4. battery cables $14
    5 remote solenoid kit. $23
    6. carb was shot, buddy had a new 750 $175
    7. old hei cap was bad, weight post shot
    new hei $110
    8 charging system went nuts.
    internal alt and a set of plugs $92
    9. rpm needs a scoop. $ 330 cowl hood.
    not counting oil, antifreeze and the misc stuff I had in the shed.
    still need a set of bb springs.
    In the end, it was worth it. jim
    brooksman9 and muscl car like this.
  2. RS1979
    3,814
    776
    Jun 18, 2013
    Memphis, TN
    I thought the story was going to end bad. Glad it worked out for you. How's she running?
  3. muscl car
    21,801
    701
    Jul 8, 2001
    High Desert of Hesperia Calif
    Put a 8-71 blower on it , I know you want to !!!!
  4. RS1979
    3,814
    776
    Jun 18, 2013
    Memphis, TN
    Then he'd really have a blown head gasket. lol
  5. xten
    xten Veteran Member
    3,086
    1,854
    Sep 24, 2014
    Pittsburgh, Pa.
    Glad it was worth it to ya Jim. Good thing you already had a lot of the stuff. It could have been a hell of a lot more $$$.
  6. Jimmac
    395
    71
    Dec 24, 2013
    tucson az
    been hoarding parts for awhile, 454 was originally going into the 66 chevelle but changed my mind at the last minute.
    The motor runs really good, no smoke, 40psi oil pressure.
    I've got a set of 3.31 gears and a eaton posi I'd like to install someday to replace the 3.07 and lock tire. jim
  7. RS1979
    3,814
    776
    Jun 18, 2013
    Memphis, TN
    Sounds good Jim
  8. 1980RS
    1980RS Veteran Member
    3,538
    645
    Jun 17, 2006
    MN
    I have been hording 454 stuff for about 20 years, just getting to use it now. I still like my Small Blocks though, they were damn quick and fast for they were. Just bought an 1150 Dominator I figured I could put it on something big, like a block.
  9. badazz81z28
    17,133
    553
    Las Vegas, NV
    Your exact scenario is why I got an LS1...Back in 2009 ish...I had a GEN V block, forged rotating assembly, Vic Jr heads...all the odds and ends and it kept adding up!!! Looked at over all cost and power...Sold it all and bought the LS1.
  10. Jimmac
    395
    71
    Dec 24, 2013
    tucson az
    if you dont count the hood, I think the out of pocket cost was under 800 including all the stuff I collected.
    I'm pretty sure I couldnt get into a ls swap for close to that since I dont have any parts or any background on LS swaps. I know they run great, make a ton of hp. I dont think I could pull a motor out and have a LS driving out of my back yard in 2 weeks working on it after work. jim
