JB Weld vs. 3M Panel Adhesive
Discussion in 'Body Restoration' started by NeoNeuro, Sep 24, 2017.
  1. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    Hey Guys,
    Is JB Weld a suitable substitute for 3M Panel Adhesive? It's around $85 to get a tube of panel adhesive, the gun, and mixing tips. JB Weld is about $5 a pack. Huge price difference!
    I want to move the fender vents on my 78 Z28 to the inside of the fender. Gluing seemed to be a better option than welding. I read a post on here a while back where someone used panel adhesive, but I wasn't expecting it to be laced with gold. :D What do you think? Thanks.
  2. jimrr
    jimrr Veteran Member
    1,332
    306
    Jun 12, 2016
    sarasota
    no, not even close..............
  3. PalmbchZ28
    PalmbchZ28 Veteran Member Gold Member
    759
    322
    Jan 29, 2017
    West Palm Beach Fl
    J-B Weld .....JB Stands for just barely.
    Zstar likes this.
  4. Gary S
    22,513
    789
    The JB weld I'm familiar with is metal and works on metal surfaces that don't flex. Panel adhesive is for plastics and other materials that flex.
  5. budro6968
    budro6968 Veteran Member
    3,207
    507
    Apr 2, 2016
    Jax Florida
    Look at the end where he shows how he mounted the vents in side. Pretty slick and removable.
    Zstar likes this.
  6. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    panel bonding adhesive is specifically for metal.
  7. NeoNeuro
    188
    Aug 4, 2014
    Panama City, FL
    Thanks everyone. I think I'll just break out the MIG. A little more work, but a whole lot cheaper.
    PalmbchZ28 likes this.
  8. tom3
    tom3 Veteran Member
    11,950
    333
    Aug 1, 1999
    ohio
    Never had a bad experience or failure with JB Weld. Amazing stuff. Have used it to "weld" nuts in a no access area and bolt on a part, worked fine. I wouldn't hesitate to use it on those vents either.
  9. FlaJunkie
    6,258
    184
    Mar 24, 2001
    Rockledge, Florida
    I think JB can handle the vents with no issue. I used it to seal a crack in my oil pan while it was on the car.
  10. 70lt1z28
    3,367
    662
    Oct 3, 1999
    Beavercreek, Ohio, USA
    JB Weld is good stuff for sure. There is a youtube video where a guy used it to cast a complete lawn mower engine head with the stuff. The engine ran for like 5 minutes until it eventually cracked, probably from the heat.
    budro6968 likes this.
