Jegs cams
Discussion in 'Engine Topic' started by sooner, Jun 26, 2009.
  1. sooner
    sooner Veteran Member Lifetime Gold Member
    1,416
    Mar 11, 2009
    Perry,Ok
  2. anesthes
    anesthes Veteran Member Lifetime Gold Member
    868
    Jun 17, 2009
    Salem, NH
  3. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,373
    Mar 30, 2001
    Joplin Mo. 64801
    Most likely the same old PAW, JC Whitney, Summit, ETC cams from the early 70's
  4. anesthes
    868
    Jun 17, 2009
    Salem, NH
  5. Cmurphy
    Cmurphy Member
    37
    Oct 12, 2008
    Boulder City, NV
    I had a local shop build an engine using that first one in my engine with the 510, 533 lift. Have not fired her up yet. Hoping to have it running in the next 2-3 weeks. I'm still confused about the lobe seperation and how it effects torq, top end, and Vac. Can someone tell me what to expect with this cam?
    This is what I have. 388ci. flat top pistons, RHS Alum 64cc heads, TH350 w/3400 stall and soon to have 4.10 rear.
    My sons and I are using this car to take to the strip and weekend cruises around town.
    This is my first build and tinkering with cars in over 20 years, so it seems like I am relearning everything as I go.
    Thanks
  6. 1980z28fromhell
    1980z28fromhell Veteran Member Gold Member
    258
    Sep 20, 2003
    hanford ca
    ive used jegs house brand junk before and sent it all back ... a cam is not a good place to save a few dollars ,, good luck
  7. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    The 200002 is the good old Performer cam!
    pdq67
  8. Cmurphy
    Cmurphy Member
    37
    Oct 12, 2008
    Boulder City, NV
    I wasn"t trying to save a few bucks..... Do they use poor or cheap materials to make the cam?????? What exactly makes them JUNK? Old type of grind? That doesn"t make them junk.
    Could you answer any of my specific questions about lobe?
  9. TooLateVTEC
    TooLateVTEC Veteran Member
    1,451
    Dec 5, 2005
    Fredericksburg,Va
    Im sure he meant junk as in they are old designs with old school lobe patterns.
    That 114 means the RPM range is going to be later in the band....meaning your going to have to turn it more RPM to "get it to run" so to say. That also gets them to not have much overlap so its not going to sound too radical either.
    They are probably alright for what your doing, but definately not good enough to be drag raced heavily.
