JohnL71RS’s Project restart…..
Discussion in 'Project Progress' started by JohnL71RS, Nov 11, 2010.
  1. JohnL71RS
    JohnL71RS Veteran Member
    1,668
    52
    Apr 12, 2010
    Marrero, LA
    Hi, my name is John. I live south of New Orleans, LA. My story starts way back in 1985 when I saw this 1971 RS Camaro around the corner from my boss’s house. The owner just put the for sale sign on her. I was only 17 at the time so I went home and asked my mother to buy the car for herself and I would purchase it from her overtime. She had just totaled her 1979 Trans Am so she needed a daily driver. The car was in mint condition. Originally had the lime green, but had since been repainted Emerald green. The owner purchased the car 7 years prior from the original owner. I was allowed to drive it part-time till mid 1986 when it was turned over to me. It had a 350 motor and 350 trans with the RS package. I changed the intake, carb and put headers on it.
    In 1988, I decided to build a big block for her. I bought a couple of engines and finally stuck with a 454. I had it rebuilt by a friend with 11:1 free floating forged pistons, Isky Z33 cam, LS6 original intake, Mallory distr (tuned with advance curve to match my stall convertor), Holley 750 Dual feed double pumper carb and Turbo 400 trans with a 3500 TCI convertor. I bought a Ford 9” rearend and had the axles drilled out for Chevy bolt pattern and had the 3” studs pressed in. Had to take out the welded spider gears and replace with limited slip with 4:56 gears. I had a friend of mine who owned a speed shop and I got him to change out the rear-end and make the sub frame connectors. He welded in the custom sub frame connectors. I think he made them from 2x3 sq tubing and they slid into the existing frames. That made a BIG difference when I drove it. With the original rear-end, it would barely get out of its way.
    I wanted this car to be a restified car. I wanted to restore it to a stock look, but could go to the track and eventually get into the 10’s. I wanted it to be able to be a street drivable car as well. I started seeing rust bubbles under the vinyl top and decided to get a professional to fix the damage before it got any worse. I had the vinyl top removed and he was suppose to fix the rust issues.
    Later on I will discuss his workmanship. With a new job taking up all my time and a soon to be wife, the car just got driven a couple of hours here and there. I bought my house in 92’ and in 93’ I built a 22x26 garage in the backyard.
    I knew I didn’t have a lot of experience in bodywork, so I had a friend with a 1970 GMC that needed a lot of replacement sheet metal and work. I bought a welding machine and already had an air compressor. BTW, at the time I was a Fabricator in the oilfield. So I was experienced in fitting metal and welding, just not sheet metal. So over the next year, I learned on his truck. Replaced floor pans, rocker panels, side cab pieces, etc. I did it for free, but gained a lot of experience.
    I decided to start on my Camaro project around 95’. I decided to sand down the body work I paid a professional to do a few years ago. He didn’t fix the rust holes anywhere. He just tacked a piece of sheet metal over the holes on the roof and guess what happened. The small holes became a hole the size of his patch. He only used bondo over the holes elsewhere.
    I also noticed rust bubbles around the wheel welds on both sides. I could feel the holes in the floor pans as well. My heater core leaked when I was driving it and it contributed to the rusting of the floor pans. I started the tear down of the car. The floor pans were very bad and after some sanding, noticed that the car was wrecking in the passenger side door and rear quarter. Ordered the floor pans, rear panel, both fenders, both quarter panel skins, upper/lower fr valence panels and trunk lid. The rear panel had extensive bondo on the lower section and the trunk lock area was heavily damaged when someone broke into my car to steal the stereo equipment. I replaced the floor pans and rear truck panel. Below are some pics. Unfortunately, I can’t find all my pics of my floor pan replacement. When I find them I will put in thread.
    This task took awhile since I was still working many hours. I mostly worked 6-7 days a week 10-12 hrs a day. I worked in a fabrication shop and traveled offshore to install the structures. Winters were the only slow season for us and down here we don’t get much of a winter. So I get the floor pans in and the rear panel changed. I also had my friend at his speed shop custom bend me a roll cage for my car. I put in the main loop and rear pipes in during the floor pan change. They stopped making the full quarters so I bought some quarter skins to fix the rear. I decided I didn’t like the skins so I bought the patches for the fr and rear of the rear wheel. Changed out the passenger side and started the driver’s side. I had to hand fabricate the trunk extension repairs because the extensions weren’t available in repop.
    From there it sat till very recently. Since that time, I have gone to college and gotten my degree in Information Technology and changed careers. Had to deal with smaller salaries starting off and didn’t have any money to work on the car. Then Katrina came and screwed up everything. But finally, I have a stable job with Tulane University with great benefits. Now I have the time but finances where all screwed up with being laid off for awhile. Now I have my finances under control and the time so I decided it was time to restart my Camaro project. BTW, going to cruise nights and having my friends ride me about my car helped push me as well.
    So I reorganized the garage and started up the project again. I have recently purchased and received both quarters, trunk extension, and rear panel. I have test fitted my 3 pc rear spoiler, taken the dash out, wiring, etc. I never painted the interior floor pans and they had lots of surface rust on them. The roll cage had rusted as well. I went out and bought a small blasting pot and blasting the interior of the car. I also blasted the cage. I then sprayed with self etching primer. Later on I will put epoxy sealer and the original red oxide primer.
    doggy70 and Lenny like this.
  2. JohnL71RS
    1,668
    52
    Apr 12, 2010
    Marrero, LA
    Here is my plan for the Camaro. I will be doing a complete frame off restoration. I want the car to be restored to look original, but I like to go fast as well. I am changing both quarters, trunk extensions and probably the rear panel again. If I can get the quarters off without destroying the new rear panel, then it will not change it. I will build my own rotisserie from some plans I found online. I will cut off the front sub frame, since it is welded to the sub frame connectors.
    I will fabricate the sub frame connector to rebolt to the fr sub frame. I will take off the sub frame and have every part I can powder coated. Including the sub frame, radiator support, rear end, and all other components I can send. I got a good deal from a local powder coating business. I will go through the engine since it has sat up so long. Replace all the bushings on the sub frame. Replace the limited slip with a posi unit. Put a 4 link setup under the rear. Restore all lamps, wiring, and interior as needed. I know I forgot some stuff, but keep following my thread and it will be discussed.
    This is my story and I will probably change things as I go. Thanks for taking the time to read all my history. Now the fun can start.
    doggy70 likes this.
  3. JohnL71RS
    1,668
    52
    Apr 12, 2010
    Marrero, LA
    About a month ago, I drove up to San Antonio, TX to cut the trunk divider out of 73BadBob’s donor car. It was a great road trip and I got to meet a great guy from NastyZ’s site. The following pics are from Bobs thread. Thanks Bob.
  4. Teamchevy
    Teamchevy Veteran Member Gold Member
    1,612
    Aug 31, 2008
    Peterborough, Ontario
    Looking forward to seeing your progress as your "restart" your project John! ;)
    Dave
    :bowtie:
  5. 73BadBob
    73BadBob Veteran Member Lifetime Gold Member
    923
    May 29, 2008
    san Antonio, Texas
    No problem. I look forward to seeing your progress.
    Francesco and Dean70Z28 like this.
  6. brooksman9
    brooksman9 Veteran Member
    6,114
    196
    Jun 10, 2007
    Olive Branch, MS
    I like it. Especially in this pic. Glad to see you were able to keep it after all these years. Will watch for your progress. :bowtie:
  7. Double R Restorations
    2,551
    31
    Jan 11, 2002
    Great story about the history of the car. Looking forward to seeing the progress.
  8. JohnL71RS
    1,668
    52
    Apr 12, 2010
    Marrero, LA
    Over the past few months, I have sandblasted the interior of the car. Since replacing the floor pans, I never sprayed the inside of the pans or the rollcage. Well rust set in and I had to get rid of it. I sanded then blasted all the interior and sprayed some self-etching primer on it. My local paint supply store and friends that are bodymen suggested that I use the self-etching primer first then epoxy over. It might be an overkill, but wanted to make sure the rust wouldn’t come back.
  9. JohnL71RS
    1,668
    52
    Apr 12, 2010
    Marrero, LA
    A few weeks ago, between the renovations on my spare bedroom, I sanded down my passenger door and sealed it with a rattle can sealer paint. This is just temporary because I had sanded the door down to bare metal and it had surface rust all over it.
    My goal is to get rid of all the rust I can find. You would be amazed how fast run can happen on bare metal when rust is present. I sanded down the rear quarters and left unprimed for years. Not until it rained one day and the breeze blew in some mist from the rain that it actually started to rust. From there on, everything on the car that was bare metal started to rust.
    I am trying to get the car leveled out today and clean up the garage so i can start cutting off the 1/4's, trunk ext, and maybe the rear panel. Should have more updates soon.
  10. JohnL71RS
    1,668
    52
    Apr 12, 2010
    Marrero, LA
    Thank all of you for checking out my thread. All of you have me inspired to work on my car. Please feel free to voice your opinions about anything in my thread. Your comments and suggestions are always welcomed.
    Thanks again.
