Thursday I was busy working on the ps wheel housing. I grinded the lip where the spot welds were. Then i used the air chisel to break it off. Came off real easy. The only place that was a PITA was the lower section behind the door. I finally got everything off and grinded down. After many times of triming and bending I got the new wheel housing temporarily in place. Today I will be fixing all the dented inner frames and patching the rusted areas. Will have more pics tonight or tomorrow.
Yesterday wasn't too productive. I only repaired spots I damaged during removal of panels and fixed a few rusted areas. I had to take out a little time setting up my welding machine for the new .30 wire. Never used this size before so i had to practice on different amps to figure out what type of welds to do. Here are a couple of spots that I cut off the rust and replaced with new metal. Next piece Will be out there again today. More updates to come.
Thanks for the compliments everyone. I am trying to rid the ps frame of rust. I spent all day yesterday testing the ps 1/4 then fixing the rust on the lower pillar frame. I cut out the rusted metal and made a new piece. Ran out of time last night and couldn't get everything primed and sprayed with weld through primer. Today it is turning very cold down here. So I will spend most the day with the family and then enjoy the Saints game tonight. I think the weather is going to get warmer for next weekend. Will update with pics once the repair is finished. Thanks for checking out my progress.
I have a question for you guys. Did anyone have this problem on the trunk extensions. The trunk ext comes out further than the inner brace. I tried the 1/4 with the ext off and on and it bends to either. Should i modify the existing brace behind the rear panel or should i modify the tr extension to go behind the brace. I think i need to modify the tr extension. the brace behind the rear panel is straight from left to right. Modifying it would put a bend in the rear tr panel. Any suggestions from you guys who had changed your tr extensions would be appreciated. thanks,
John, I think you have to put on your quarter panel and get it fitting into the notch on the drop off panel. Tack it on then push it over to minimize the gap on the tail panel. I am doing the driver side drop off panel on mine now and the repo drop off i bought is not bent right. I had to bend it another 10 to 15 degrees to get it close. It is also maybe 1/4" lower than the original where the brace welds on to it. I am no expert but i think you got to put the quarter on before you can move it to the tail panel. I will be finishing mine right or wrong tomorrow and will post some pictures for what they are worth.
