junk yard parts
Discussion in 'High Tech Retrofits' started by blue1978rs, Feb 4, 2012.
  1. blue1978rs
    blue1978rs Member
    45
    May 19, 2011
    maryland
    Good m0rning all i have been searching the post till my eyes are crossed, i want to do some cheap upgrades to my 78 but im having alot of confussion
    i see post talking about the s10 rear disk brake setup, however the cost is showing around 450 bucks, why is this better than using summits rear disk brake set up for 450 all new parts. can somebody please give me a short list
    of junk yaard stuff that works on 2ng gens {78}. and please dont refer me to anymore stickies at this point i dont need to know how to do them just want to know what works.
  2. Batman
    Batman Administrator Staff Member Lifetime Gold Member
    8,673
    Dec 13, 1999
    Mission Viejo, CA, USA
    If you're comparing the cost for the entire rear end at the yard vs. just grabbing the calipers, rotors, and mounting plates, you'll see where you're mistaken. Just grab the above parts and leave the rest at the yard. It should be about $150-$200 at most.
  3. blue1978rs
    blue1978rs Member
    45
    May 19, 2011
    maryland
    yeah maybe im wrong the guy was including all the needed for this converison
    he had vette brake booster prop. valve, ect... are all these parts needed??
    i guess im looking for a list of stuff that will fit and works well without a whole lot of fab. simple bolt on parts i guess
  4. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Go to the brake and suspension section.
    This has been discussed countless times with parts lists and part #'s listed.
    Yep....it's in the sticky at the top. S-10 conversion.
  5. blue1978rs
    blue1978rs Member
    45
    May 19, 2011
    maryland
    i know i know stickies... i was just hoping someone could just give me a list of junkyard upgrades forget the brakes.....wow, im not looking for part numbers ect. just want to know what people have done..... looks like im on my own.
  6. Fbird
    3,868
    596
    Feb 12, 2011
    atlanta, ga
    the s-10 rear disc brake would be a JUNKYARD UPGRADE. What other kind of UPGRADES would you be interested in.
    Junkyard upgrades:
    bigger better brakes
    4th gen dash and complete interior
    LS motor
    6 speed automatic
    that should be enough for this trip to the yard! :eek:
  7. gregs78cam
    gregs78cam Member
    51
    May 2, 2004
    Spirit Lake, ID
    If you want just general upgrades to a basically stock car, then my short list would this:
    Factory style gear reduction starter, $9-$15
    '93-'95 Throttle body injection, $50-$150
    '97-'00 Sunfire/Cavalier Fuel pump for above EFI, $13
    Taurus Electric fan run by above PCM, $15
  8. blue1978rs
    blue1978rs Member
    45
    May 19, 2011
    maryland
    i guess im asking about stuff like, swaybars, seats, seatbelts, rears, springs just what ever is out there and what works.
  9. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Find a late 70s Z28 or Trans Am and start pulling the suspension.;)
    Tom
  10. ATM
    ATM Veteran Member Lifetime Gold Member
    2,265
    Oct 10, 2009
    Morris, Illinois
    Go to Google. Type in what you are looking for. Follow what you type in with site:nastyz28.com. Feel the power.
    Swaybars. I seriously doubt that you are going to find a performance upgrade in a junkyard.
    Seatbelts. I thing that you can make about fourth gen camaro belt set work.
    Seats. Any front seats pretty much will work with some modifications and/or using the stock rails.
