Just an update (pix)
Discussion in 'Body Restoration' started by phat80, Jan 8, 2017.
  1. phat80
    phat80 Veteran Member
    992
    Jan 4, 2013
    Victoria BC
    Well. I haven't posted in a while but I've been busy on the body prep. Christmas eve I finally got the primer/sealer shot. Man the masking and overspray apron took a long time to do. After I sprayed I went in to remove the mask and start installing the windows and stuff but then...
    I remembered a "little" job I had bee putting off for many, many weeks. I installed 2" drop springs and spindles..apparently that was a little over the top, OTT as we say,. The tires were rubbing on the inner fender.
    So, I thought before I do ANYTHING else I'm going to swap out the springs. So I attacked that job! I'm about 3/4 done.
    The calm after the storm.
  2. Venom73
    Venom73 Veteran Member Lifetime Gold Member
    1,411
    Feb 4, 2007
    Louisville, Ky
    Keep up the good work
