Just pulled trigger on FiTech
Discussion in 'High Tech Retrofits' started by 408maro, Mar 6, 2016.
  1. Maine1
    Maine1 Veteran Member
    165
    Nov 19, 2014
    Franklin County, Maine
    So you are not using the FiTech's timing control?
  2. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    Ditched the fuel command center and went with a tanks inc efi tank. With the corvette filter
  3. redriderjf87
    redriderjf87 Veteran Member
    131
    11
    Jan 23, 2016
    Quad Cities, IL
    That's correct. Crow tastes good :)
  4. Maine1
    165
    Nov 19, 2014
    Not for 1 second will you regret going this route. What did you use for a air cleaner base? When I ordered from Tanks they set me up with all straight twist loc AN fittings and when it came time for my air cleaner base I had to order a 45 otherwise I would never of gotten a air cleaner on it.
  5. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    Mine fit with a straight fitting. I have a air cleaner spacer between the fitech and air cleaner and fits perfectly
  6. redriderjf87
    131
    11
    Jan 23, 2016
    Quad Cities, IL
    I had to use a 90 degree fitting under the air cleaner to fit, and use the 45 degree one on my FCC. With the 90, my standard size (13 inch?) air cleaner base just cleared it.
  7. BonzoHansen
    19,349
    724
    Jun 1, 2005
    Scott from Hamilton, NJ
    Can you put a drop base filter on it? I'm wondering if it will fit under a flat hood on a sbc with and rpm or air gap intake. Stock throttle cable?
  8. redriderjf87
    131
    11
    Jan 23, 2016
    Quad Cities, IL
    I can't comment on a flat hood (I have the Z28 cowl hood), but I will say my air cleaner sits lower on the FiTech than it did on my Holley 650, using an rpm intake. So I would say most likely it would fit if it did with a carb.
  9. Racer X
    Racer X Veteran Member
    442
    Aug 26, 1999
    NJ
    WOW mine just came in today ordered it on April 17!
    don't know when I will be able to put it in though now.
  10. Racer X
    442
    Aug 26, 1999
    NJ
    I put this together...Video show
    [youtube]8GSNzAmo5tg[/youtube]
